Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can´t get acces to media [SOLVED]
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-14
02:37 PM
2013-02-14
02:37 PM
Hi there.
I just bought a Readynas duo, running firmware RAIDiator 4.1.10
I´ve installed it following the manual. but i can´t get acces to media or backup ?
When i´m in the sharing menu, its say to both, CIFS DISABLED. i cant add a Hosts allowed access (if that is what im missing)
i dont know, i tried for hours now, and i cant even download anything from transmission :s
Message 1 of 8
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
04:24 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
04:28 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
04:44 AM
2013-02-15
04:44 AM
Re: Can´t get acces to media
it doenst help me. verytime i try to change something in share settings, it just go back to the default :s i cant change anything 😞
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
04:58 AM
2013-02-15
04:58 AM
Go to System > Config Backup. What happens if you try to download a Config Backup?
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
05:18 AM
2013-02-15
05:18 AM
CIFS DISABLED ? I am not sure how this happened, my best guess is enable it again from frontview. Go to Services> Standard Protocol services >Tick the box CIFS and click apply. If it is already ticked then untick it and click apply then tick it again and click apply. Now go to the share and check if CIFS is enabled. This option is under shares> share listings > change default access to read/write on the share. Otherwise this sounds like a corrupt samba file on the NAS. Try doing an OS reinstall as per this link, http://www.readynas.com/kb/faq/boot/how ... _boot_menu. This will default the access on the share.
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
06:08 AM
2013-02-15
06:08 AM
mdgm wrote: Go to System > Config Backup. What happens if you try to download a Config Backup?
when i check "everything" and press download. Nothing happens ?
EDIT: It seems like i can download all configs, except Data Volumes
GoggiP wrote: CIFS DISABLED ? I am not sure how this happened, my best guess is enable it again from frontview. Go to Services> Standard Protocol services >Tick the box CIFS and click apply. If it is already ticked then untick it and click apply then tick it again and click apply. Now go to the share and check if CIFS is enabled. This option is under shares> share listings > change default access to read/write on the share. Otherwise this sounds like a corrupt samba file on the NAS. Try doing an OS reinstall as per this link, http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu. This will default the access on the share.
The tick was on, its not that. ive tried to untick and tick it again, no help. ill try to make a os reinstal. here is a picute.
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
08:23 AM
2013-02-15
08:23 AM
PROBLEM SOLVED:
could not factory reset it by holding reset for 30 sec. BUT, in frontview i could, and now it works !
Thanks to everybody for the time they spent !
Message 8 of 8
