× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can't open admin page after reinstall OS
Jianxin2023
I forgot admin password, so reinstall OS. But I can't open admin page after reinstalling OS, page shows ERR_CONNECTION_RESET,  shows good in RAIDar. Would you please give me advice to fix this issue?
Message 1 of 5
Guru
Re: Can't open admin page after reinstall OS
One possibility is that the browser has the old NAS password stored.  Try opening an incognito browser window to test this.
If you applied the add-on to add TLS 1.2 support to the web server, then that would likely have been undone when you did the OS reinstall.  You can try Edge in IE mode, or use FireFox (changing the tls security to allow TLS 1.0 in about:config).
Message 2 of 5
Jianxin2023
Thank you for your advice, I can login by Edge in IE mode, would you please advise if I can change Chrome setting so I can use Chrome to login?
Message 3 of 5
Guru
Unfortunately, no.
But you can install this add-on (provided by @WhoCares_), which adds TLS 1.2 support.  Then you can log in with Chrome.
Message 4 of 5
Jianxin2023
Thank you for your advice.
I will try that .
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 616 views
  • 1 kudo
  • 2 in conversation
Announcements
