× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can't turn on SMB
bubu
Can't turn on SMB
Hi
I have RND516 with 6.10.8 firmware.
Since today I had issue with my MAC and TimeMachine through AFP on RND.
I tried trough SMB but since SMB start and stop.
Impossible now to turn on SMB in NAS services setup.
I uninstalled SMB plus it is the same
Somebody can help me?
because I can't acces now to my RND with finder 😞
Laurent
Message 1 of 31
Accepted Solutions
Guru
Re: Can't turn on SMB
@bubu wrote:
It did it right away and also manual reboot
same issue after reboot
Ok.  Then the script didn't run.  I think the issue is that the certificate has expired.
Try these commands instead
cd //
wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
chmod +x ./share_lun_ui_fix.sh
Message 28 of 31
All Replies
Guru
Are you getting an error when you try?
FWIW, I am not yet running 10.6.8 on my x86 NAS, but I am able to enable/disable SMB on an RN102.
Message 2 of 31
bubu
No error message
I turn it on but it turn off automatically after few seconds
Message 3 of 31
Guru
@bubu wrote:
No error message
Have you tried downloading the log zip file and looking for errors in there?
Message 4 of 31
bubu
Which log because there are a lot :
  • in system.log
Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 03 07:17:01 serveur CRON[16952]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session closed for user root
Oct 03 07:22:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 07:23:59 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"}
Oct 03 07:31:30 serveur connmand[3500]: ntp: adjust (slew): -0.000126 sec
Oct 03 07:32:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 03 07:39:01 serveur CRON[17143]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session closed for user root
Oct 03 07:42:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 07:48:34 serveur connmand[3500]: ntp: adjust (slew): +0.001058 sec
Oct 03 07:52:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 08:02:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 08:05:38 serveur connmand[3500]: ntp: adjust (slew): -0.051464 sec
Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 03 08:09:01 serveur CRON[17417]: (root) CMD (  [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session closed for user root
Oct 03 08:12:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 03 08:17:01 serveur CRON[17530]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session closed for user root
Oct 03 08:22:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 08:22:43 serveur connmand[3500]: ntp: adjust (slew): +0.065669 sec
Oct 03 08:24:15 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"}
Oct 03 08:32:21 serveur clamd[10097]: SelfCheck: Database status OK.
Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET / HTTP/1.1" 302
Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET /admin HTTP/1.1" 401
Oct 03 08:35:52 serveur apache_access[4708]: Admin session started from 192.168.111.112
Oct 03 08:36:12 serveur apache_access[4708]: 192.168.111.112 "GET /ispdb.xml?_dc=1664778972036 HTTP/1.1" 200
Oct 03 08:36:18 serveur wsdd2[17976]: starting.
Oct 03 08:36:19 serveur wsdd2[17976]: cannot read workgroup from testparm
Oct 03 08:36:19 serveur wsdd2[17976]: cannot read netbios name from testparm
Oct 03 08:36:19 serveur wsdd2[17976]: Terminated received.
Oct 03 08:36:19 serveur wsdd2[17976]: terminating.
Oct 03 08:36:39 serveur apache_access[4709]: Suppressed 4 duplicate messages
Oct 03 08:36:39 serveur apache_access[4709]: ::1 "OPTIONS * HTTP/1.0" 200
Oct 03 08:38:20 serveur apache_access[4708]: 192.168.111.112 "POST /dbbroker HTTP/1.1" 401
Oct 03 08:38:55 serveur dbus[3362]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Oct 03 08:38:55 serveur dbus[3362]: [system] Successfully activated service 'org.opensuse.Snapper'
Oct 03 08:38:55 serveur snapperd[18114]: loading 3958 failed
Oct 03 08:38:55 serveur snapperd[18114]: loading 4043 failed
Oct 03 08:38:55 serveur snapperd[18114]: loading 4057 failed
Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed
Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed
Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed
  •  in smbstatus.log
using configfile = /etc/samba/smb.conf
  • in status.log
[22/10/03 00:00:22 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonCloudDrive.
[22/10/03 00:00:23 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonPhotos.
[22/10/03 00:00:25 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Immersion.
[22/10/03 00:00:26 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Photos.
[22/10/03 00:00:27 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prive.
[22/10/03 00:00:28 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophecy.
[22/10/03 00:00:29 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophezine.
[22/10/03 00:05:21 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Immersion.
[22/10/03 00:05:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophecy.
[22/10/03 00:06:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prive.
[22/10/03 00:06:54 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophezine.
[22/10/03 00:14:36 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job NAS.
[22/10/03 00:21:28 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Photos.
[22/10/03 02:20:37 CEST] notice:volume:LOGMSG_DISKTEST_COMPLETED_VOLUME Disk test completed for volume data.
[22/10/03 08:36:18 CEST] info:system:LOGMSG_PROTOCOL_ENABLED Service protocol SMB is enabled.
but still SMB button not green and can't see NAS in network only access by http
Message 5 of 31
Guru
Normally I'd look in kernel.log, system.log, and systemd-journal.log, and see if there are any SMB related errors or crashes.  dmesg.log also sometimes has useful information.
You are showing some other errors (likely unrelated) with snapshots that might need to be sorted out at some point.
Did this problem happen as soon as you upgraded to 6.10.8?
Have you tried an OS reinstall?
Message 6 of 31
bubu
How can reinstall it ?
Any issue for my data? because I can't loose them.
Message 7 of 31
Guru
Are you seeing any warnings about a full root partition in the NAS web ui?  If you are, then don't try the OS reinstall.
The process for doing an OS reinstall from the boot menu is described on pages 120-121 here:
I don't know that it will fix it, but your NAS is behaving oddly, so it might.
It shouldn't affect data.  It will
  • reset the admin password to password
  • reset the network configuration to use dhcp with no bonding
  • disable volume quota (which can be re-enabled on the volume settings wheel).
But there is something going on with the data volume as well (snapshots that cannot be found or maybe accessed).
It sounds like you have no backup for the NAS - something you should put in place when you get past that.
Message 8 of 31
bubu
Thank you
I have external USB backup but it take very long time to restore 😛
Message 9 of 31
bubu
Very bad new 😞
- restore done
- but still can't enable SMB
- and my DATA seems to be always on HDD but NAS can't see them 😞
Message 10 of 31
Guru
Are the shares showing up on the shares page?  Can you browse a share, and see the data?
Message 11 of 31
bubu
Can't see any of my folder in data
but it seems datas are still there because at the bottom only 4.8To free
Message 12 of 31
Guru
Was all your data in the home folders?  Or did you create shares?
Have you ever used the linux command line (ssh)?
Message 13 of 31
bubu
there were shared folder not in home folder
I wasn't using since long time ssh but I can.
Message 14 of 31
Guru
Ok.  Enable ssh in the web ui (system->settings->services).  Then connect with ssh (terminal will work), and log in as root, using the NAS admin password.
Then take a look at the data volume (ls /data) and see if you see the shared folder(s).
While you are logged in, you could also take a look at the SMB service status with systemctl status smb
If the service isn't running, you could also try systemctl start smb and see what happens.
Message 15 of 31
bubu
Please see bellow details :
Spoiler
root@serveur:~# ls /data
AmazonCloudDrive AmazonPhotos home Immersion Musique NAS Photos Prive Prophecy Prophezine Vidéos
root@serveur:~# systemctl status smb
● smb.service - Samba SMB Daemon
Loaded: loaded (/lib/systemd/system/smb.service; disabled; vendor preset: enabled)
Active: inactive (dead) since Tue 2022-10-04 21:37:19 CEST; 18min ago
Process: 23558 ExecStart=/usr/sbin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=1/FAILURE)
Main PID: 23558 (code=exited, status=1/FAILURE)
Oct 04 21:37:18 serveur systemd[1]: Starting Samba SMB Daemon...
Oct 04 21:37:19 serveur systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE
Oct 04 21:37:19 serveur systemd[1]: Failed to start Samba SMB Daemon.
Oct 04 21:37:19 serveur systemd[1]: smb.service: Unit entered failed state.
Oct 04 21:37:19 serveur systemd[1]: smb.service: Failed with result 'exit-code'.
root@serveur:~# systemctl start smb
Job for smb.service failed because the control process exited with error code.
See "systemctl status smb.service" and "journalctl -xe" for details.
root@serveur:~# systemctl status smb.service
Active: failed (Result: exit-code) since Tue 2022-10-04 21:56:15 CEST; 21s ago
Process: 25609 ExecStart=/usr/sbin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=1/FAILURE)
Main PID: 25609 (code=exited, status=1/FAILURE)
Oct 04 21:56:15 serveur systemd[1]: Starting Samba SMB Daemon...
Oct 04 21:56:15 serveur systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE
Oct 04 21:56:15 serveur systemd[1]: Failed to start Samba SMB Daemon.
Oct 04 21:56:15 serveur systemd[1]: smb.service: Unit entered failed state.
Oct 04 21:56:15 serveur systemd[1]: smb.service: Failed with result 'exit-code'.
  • all my folders still there, but can't see them in http admin page of RND
  • for SMB still error also in SSH
Message 16 of 31
Guru
Can you run these commands?
  • df // -h
  • btrfs fi df //
Message 17 of 31
bubu
root@serveur:~# df // -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 2.0G 1.8G 54% /
root@serveur:~# btrfs fi df //
Data, single: total=2.85GiB, used=1.88GiB
System, DUP: total=8.00MiB, used=16.00KiB
Metadata, DUP: total=204.56MiB, used=23.12MiB
GlobalReserve, single: total=16.00MiB, used=0.00B
root@serveur:~#
Message 18 of 31
Guru
One option is to do a factory reset, set up the NAS again, and restore the data from backup.
There is a repair tool that might possibly help.  But I think you would need a backup anyway, because I think there is some risk that the tool could do more damage.
Any thoughts?
Message 19 of 31
bubu
I can't do reset factory on other disk? and after replace good HDD inside.
Is it the only solution?
Message 20 of 31
Guru
A factory reset just formats the disks and, the firmware onto the disks.  If you it with a different set of disks inserted, then it would have no effect on the disks you have in the NAS now.
The repair tool might well work (and I haven't seen cases where it has done harm) - but I do see some risk to your data.  So I am recommending making a backup first.
You'd run the repair tool from ssh - the command is:
curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
Message 21 of 31
bubu
I can’t do more backup due to share folder not visible in web portal.
I have daily external usb backup and I hope everything is ok on there 😞
I have critical an volume files in RND and I can’t control 1 by 1 each of them 😞
This is a nightmare
Message 22 of 31
Guru
This is a nightmare
Understood.  You could perhaps back up manually to the USB disk (using the cp command from ssh).  Or just check it, and see what is there.
Or just try running the repair tool I linked in above.  Best to copy/paste the command, as it is long.
Message 23 of 31
bubu
Thank you
I will try this evening
Message 24 of 31
bubu
I launched it but nothing done no message.
root@serveur:~# curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
root@serveur:~#
Message 25 of 31
Top Contributors
Discussion stats
  • 30 replies
  • 3343 views
  • 0 kudos
  • 2 in conversation
Announcements
