× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can't turn on SMB
Guru
Re: Can't turn on SMB
@bubu wrote:
I launched it but nothing done no message.
root@serveur:~# curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
root@serveur:~#
Did it complete right away, or did it take a while?
Did you try rebooting the NAS after it finished?  Then see if the behavior is any different?
Message 26 of 31
bubu
It did it right away and also manual reboot
same issue after reboot
Message 27 of 31
Guru
Ok.  Then the script didn't run.  I think the issue is that the certificate has expired.
Try these commands instead
cd //
wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
chmod +x ./share_lun_ui_fix.sh
Message 28 of 31
bubu
during this time I found how to restore smb service by istalling smb plus apps
smb is now there
I launched your last script
Spoiler
Welcome to ReadyNASOS 6.10.8
Last login: Wed Oct 5 20:55:08 2022 from 192.168.111.112
root@serveur:~# cd //
root@serveur://# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
--2022-10-05 21:51:47-- https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
Resolving gitlab.codycook.us (gitlab.codycook.us)... 138.68.60.68, 2604:a880:2:d0::66:7001
Connecting to gitlab.codycook.us (gitlab.codycook.us)|138.68.60.68|:443... connected.
WARNING: The certificate of ‘gitlab.codycook.us’ is not trusted.
WARNING: The certificate of ‘gitlab.codycook.us’ has expired.
HTTP request sent, awaiting response... 200 OK
Length: 10410 (10K) [text/plain]
Saving to: ‘share_lun_ui_fix.sh’
share_lun_ui_fix.sh 100%[============================================================>] 10.17K --.-KB/s in 0s
2022-10-05 21:51:48 (101 MB/s) - ‘share_lun_ui_fix.sh’ saved [10410/10410]
root@serveur://# chmod +x ./share_lun_ui_fix.sh
root@serveur://# ./share_lun_ui_fix.sh
* Share and iSCSI Rebuild v6.10.0 *
= [Info] Share config backups folder exist (/var/backups/shares)
== [Task] Backing up existing share config backup folder
=== [Info] Completed share config backup folder.
=== [Task] Listing backup folder for a quick analysis
2022-10-05 21:42:10.369849980 +0200 583680 /var/backups/shares/shares.tar
2022-10-03 20:58:43.548893073 +0200 583680 /var/backups/shares/shares.tar.0
2022-10-03 06:25:51.334454853 +0200 132786 /var/backups/shares/shares.tar.1.gz
2022-10-02 21:14:42.914998417 +0200 33070 /var/backups/shares/shares.tar.2.gz
2022-10-02 20:23:36.490948431 +0200 33074 /var/backups/shares/shares.tar.3.gz
2022-10-02 20:01:50.179781375 +0200 33068 /var/backups/shares/shares.tar.4.gz
==== [Info] Review backup folder listing and decide to continue or restore.
==== [Decide] To cancel and manually restore from an above config, CTRL-C now... Otherwise, continuing in 5... 4... 3... 2... 1... 0...
= [Task] Discovering volumes
== [Info] 1 volume(s) found.
==== [Task] Backing up existing Snapper configs
===== [Info] Success at backing up snapper configs
===== [Task] Removing Snapper Configs
== [Task] Investigating volume /data...
=== [Info] Number of items found : 10
=== [Info] Items found: AmazonCloudDrive AmazonPhotos Immersion Musique NAS Photos Prive Prophecy Prophezine Vidéos
=== [Task] Reviewing AmazonCloudDrive
=== [Info] Found share at /data/AmazonCloudDrive
=== [Task] Recreating share configs.
==== [Info] Done with Share /data/AmazonCloudDrive.
=== [Task] Reviewing AmazonPhotos
=== [Info] Found share at /data/AmazonPhotos
==== [Info] Done with Share /data/AmazonPhotos.
=== [Task] Reviewing Immersion
=== [Info] Found share at /data/Immersion
==== [Info] Done with Share /data/Immersion.
=== [Task] Reviewing Musique
=== [Info] Found share at /data/Musique
==== [Info] Done with Share /data/Musique.
=== [Task] Reviewing NAS
=== [Info] Found share at /data/NAS
==== [Info] Done with Share /data/NAS.
=== [Task] Reviewing Photos
=== [Info] Found share at /data/Photos
==== [Info] Done with Share /data/Photos.
=== [Task] Reviewing Prive
=== [Info] Found share at /data/Prive
==== [Info] Done with Share /data/Prive.
=== [Task] Reviewing Prophecy
=== [Info] Found share at /data/Prophecy
==== [Info] Done with Share /data/Prophecy.
=== [Task] Reviewing Prophezine
=== [Info] Found share at /data/Prophezine
==== [Info] Done with Share /data/Prophezine.
=== [Task] Reviewing Vidéos
=== [Info] Found share at /data/Vidéos
==== [Info] Done with Share /data/Vidéos.
= [Info] done with /data
= [Task] Restarting readynasd to apply changes.
[Stats] Rebuilt Share configs: 10
[Stats] Rebuilt LUN configs: 0
[Stats] Migrated folders to subvolumes: 0
root@serveur://#
it seems to be there now I will test more and give you feedback
thank you 🙂
Message 29 of 31
bubu
Dear @StephenB
Thank you so much it seems to work again 🙂
I have some issues shared folder rights but I must resetup them again
Strange thing I must enable AFP share for TimeMachine because always SMB not working.
I will launch this night TM by AFP to see if everything is correct.
I will send you complete feedback tomorrow.
Message 30 of 31
bubu
Thank you @StephenB SMB and share are working fine after recreate network access and rights
I have issue with Time Macine but I will open new post because seems to be different issue.
Message 31 of 31
Top Contributors
Discussion stats
  • 30 replies
  • 3340 views
  • 0 kudos
  • 2 in conversation
Announcements
