Orbi WiFi 7 RBE973
Reply
Change file system permissions via web interface?
mike_coreit
Hi I have a ReadyNAS Pro 2 (RNDP2000). Is it possible to change the file file system permissions of a folder via the web interface?
I'm using a Windows PC to access a share which I currently have read/write access to, but when I try to create/edit a file in a particular subfolder it gives an access denied error.
Model: RNDP2000 (ReadyNAS Pro 2)|ReadyNAS® Pro 2 System|EOL
Message 1 of 3
Accepted Solutions
Guru
Re: Change file system permissions via web interface?
Go into the share settings, and then click on the CIFS icon.  There will be an "advanced options" tab on the upper right - click that.
Enter the user/group you want to own the files (nobody/nogroup works), and then set the file and folder permissions as desired.
Right under that pane there are two checkboxes:
  • Set ownership and permission for existing files and folders in this share to the above settings...
  • Grant rename and delete privileges to non-owner of files.
 Make sure both are checked, and then click on "apply" on the bottom right.  The permissions are reset in the background, there will be a popup when it completes.  It should also be logged.
Message 2 of 3
All Replies
Guru
Message 2 of 3
mike_coreit
Thank you for the quick response, that resolved the issue
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3200 views
  • 0 kudos
  • 2 in conversation
Announcements
