- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Changing from Flex-RAID to X-RAID
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was casually looking at the volumes tab of my ReadyNAS admin page.
And so I noticed that the X-RAID button was not lit. I specifically recall getting a ReadyNAS specifically for X-RAID capabilities and cannot recall at all having changed or made any setting that would set it to Flex-RAID instead. But this is beside the point.
I was looking up whether I could simply change from Flex-RAID to X-RAID by clicking the button, but I don't want to risk losing the data if I can avoid it.
What I did find, was a thread changing X-RAID to Flex-RAID from 2009. This felt fairly outdated, but it mentioned one would need to do a factory reset. A recent incident has made me want to avoid this as far as I am able.
I also found KB 22813 that states I can simply click the button and my data will be retained. Simple as pie, right? Not if you're insecure like me, no.
Long story short, can I click this button and switch to X-RAID and keep my data?
And if yes, will it increase my disk space and storage capacity? See below.
Thanks for any help on this!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your logs show a 4x2TB RAID-5 layer and a 3x2TB RAID-5 layer. Replace the 3TB disk with a 4TB disk and you should get some more expansion.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Changing from Flex-RAID to X-RAID
If you are running RAID-5 with a single volume then you should be able to switch to xraid with no data loss.
What is your current disk configuration? Are all the disks the same size?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sadly they are not the same size.
It is currently RAID-5 with Flex-RAID, like so in this order from left to right in the bays:
WDC WD30EZRX-00D8PB0 3TB
WDC WD40EFRX-68WT0N0 4TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Turning X-RAID on or off does NOT affect the data in the volume.
If you're running Flex-RAID with mixed capacity HDDs, then you are limited by the smallest HDD in your current volume.
The thread from 2009 is about X-RAID/Flex-RAID on RAIDiator 4/5.
Now, on ReadyNAS OS 6, you can switch between X-RAID and Flex-RAID (seemingly turning X-RAID on or off by the look of the GUI) without the need to Factory Default (you can't turn X-RAID back on if you don't have a "compatible" volume).
If you have a single RAID5, you can indeed turn on X-RAID and it will expand your volume by almost 2TB (a bit less if you substract overhead, etc.).
Also, please, if you're unsecure, have an external backup of your data! A RAID providing redundancy does NOT replace an external backup 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not a problem, it simply suggests that XRAID is a better mode for you.
You can turn XRAID on. I haven't tried that in this scenario, so I am not sure if the volume will automatically expand when you do. So let us know. If it doesn't immediately expand, try rebooting.
The truth is, you should feel concerned if you don't have a backup. Your data is always at risk if it is only stored on one device. Raid reduces that risk some, but it is still there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Crucial things are backed up, changed the thing to X-RAID, nothing happened, so I rebolted the device and still nothing seems to be happening in the way of expansion.
I am not seeing much activity in the logs either aside from background services started and the fact that we rebooted.
OS is 6.5.0.
I believe I saw some thread about replacing a drive and the result or progress didn't show anywhere until it was actually done. Could this be something similar? And how long would this theoretically take? I understand if there's an entire index needing to be rewritten but am not too experienced with RAID arrays myself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send me your logs (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you seeing a 10 TiB volume size on the web UI?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not seeing a 10 TiB volume in the Web GUI, no.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you upgrade disk-1 from 2 TB to 3 TB after you installed the 4 TB drives? That would explain the layering mdgm reports (which explains the 9 TiB volume size).
The easiest solution is to upgrade the 3 TB drive to 4 TB. Re-creating the volume would also give you an 10 TiB (11 TB) volume size - but would also destroy your data, so you'd need to restore it all from backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had this device for quite some time now, so if memory serves, that would be a fairly certain yes.
Let's see...
I started out with 2-2-2-2, upgraded to 2-2-4-4, then 2-4-4-4 and finally got a hold of the 3TB so I got a 3-4-4-4 setup.
So yes, I guess that would explain the entire thing. At some point during the 3-4-4-4 setup, or the 2-4-4-4 setup (I can't recall), the whole OS was factory reset or something that really looked like it, because upon logging in to the UI made me set up a new administrator's account and all the data was gone, but I could not name my volume the way it was before.
Not sure what happened back then, but that's in the past and my point to this story is that the volume may or may not have been destroyed and rebuilt at that point, if that brings any clarity at all to the layering conundrum, as it were.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Once the partitions were created for 2-4-4-4, the array could no longer use the full 3 TB.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Roger that.
I will try to get a hold of a 4TB disk instead then and return here if expansion was unsuccessful.
Thanks for all of your help! 🙂
