× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Cleanup after failed disk on readynas 214
edgylitirmor
Guide
Hi. So, a disk failed in my readynas 214. It was called Media2. Media2 had several shares on it.
The failed Media2 has been removed from the box and I'm going to add in a new disk and also name it Media2 (imaginative, I know).
How do I clean up all traces of the previous Media2 before adding the new disk and using that name?
Currently, my log files are full of errors (mostly smbd and snapperd) about missing shares. I assume the NAS won't like a new volume being created with the same name as one it believes still exists.
Is there a conf I can edit? Some magic command?
Thanks.
Message 1 of 7
Guru
Re: Cleanup after failed disk on readynas 214
Media2 must have been the volume name.
This should still show up on your volumes tab.  If so, click on the volume settings wheel and delete it.
Message 2 of 7
edgylitirmor
Guide
I did that before removing the disk.
Still seeing loads of errors in the logs.
Message 3 of 7
Guru
What firmware version are you running?
Message 4 of 7
edgylitirmor
Guide
6.10.8
Message 5 of 7
Guru
6.10.8
Do you have any experience with the linux command line ("ssh")?
Since you asked about editing a conf file, I am assuming yes.
One option is to run a repair script that is here:
This was written by a Netgear developer for support use some years ago.  Unfortunately, the certificate is expired.
However, you can still run it using these steps:
# cd //
# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
# chmod +x ./share_lun_ui_fix.sh
# ./share_lun_ui_fix.sh
Message 6 of 7
edgylitirmor
Guide
Yes
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 739 views
  • 1 kudo
  • 2 in conversation
Announcements
