- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Command line shutdown since 6.9.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi....
today I have updated from 6.9.2. to 6.9.3 and now I can't shutdown the device via a powershell script, I have get the message:
Invoke-RestMethod : 403 Forbidden Forbidden You don't have permission to access /dbbroker on this server. Apache/2.2.34 (Debian) Server at sirius Port 443 In C:\Users\pixan\Documents\Computer\Scripts\sirius_off.ps1:36 Zeichen:1 + Invoke-RestMethod -Credential $Credential -Headers $Headers -Uri $Uri ... + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
anyone a solution for this...
the script
$Hostname = "sirius" $Username = "admin" $Password = ConvertTo-SecureString "TopSecret" -AsPlainText -Force $Credential = New-Object System.Management.Automation.PSCredential($Username, $Password) $Headers = @{ "Content-Type" = "application/x-www-form-urlencoded"; "X-Requested-With" = "XMLHttpRequest" } $Xml = '<?xml version="1.0" encoding="UTF-8"?><xs:nml xmlns:xs="http://www.netgear.com/protocol/transaction/NMLSchema-0.9" xmlns="urn:netgear:nas:readynasd" src="dpv_1368497621000" dst="nas"><xs:transaction id="njl_id_1278"><xs:custom id="njl_id_1277" name="Halt" resource-id="Shutdown" resource-type="System"><Shutdown halt="true" fsck="false"/></xs:custom></xs:transaction></xs:nml>' $Uri = "https://$Hostname/dbbroker" Add-Type @" using System.Net; using System.Security.Cryptography.X509Certificates; public class TrustAllCertsPolicy : ICertificatePolicy { public bool CheckValidationResult( ServicePoint srvPoint, X509Certificate certificate, WebRequest request, int certificateProblem) { return true; } } "@ [System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy Invoke-RestMethod -Credential $Credential -Headers $Headers -Uri $Uri -Method Post -Body $Xml Write-Host "done"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Command line shutdown since 6.9.3
I have the exact same issue since installing 6.9.3. Permission denied on /dbbroker. I am also experiencing connection issues now with NAS Utils app for android, which worked fine before. I really need to be able to shutdown the NAS remotely, so I tried installing firmware 6.9.2 again, but I can't. It throws an unexpected error when I try that.
edit:
When I visited the admin page again to shut it down, I got the firmware install dialog after all. So I went ahead with it. 6.9.2 installed ok. I can now also once again remotely shutdown the NAS from the commandline. So it's definately a 6.9.3 issue. I will stay with 6.9.2 until this (hopefully) gets fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Going back to 6.9.2 was a very good idea
- Mark as New
- Bookmark
- Subscribe
- Permalink
This sounds like it might be related to a security change in 6.9.3.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using a Windows 10 PC. I had created a batch file on it, which I can run remotely using my phone. It is a similar script as the one posted by Xatosch. Got it from here: https://community.netgear.com/t5/Using-your-ReadyNAS/Remote-shutdown-on-OS-6/td-p/846137. This, as mentioned, no longer works in 6.9.3.
Indeed, the cause of it not working any longer might very well be a security fix. If so, do you perhaps know of another way to shut the NAS down with a batch file? Or does anyone else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your script will need to become a bit longer. See Curl does not work any more since upgrade to 6.9.3 on RN316
- Mark as New
- Bookmark
- Subscribe
- Permalink
