× NETGEAR will be terminating ReadyCLOUD service by April 1st, 2023. For more details click here.
Reply
Connect 10TB USB drive to ReadyNAS 3138
loco42
Hi,
I have an external USB drive w/ 10TB as of now formatted with ExFat.
It does not show up in the frontend (System page) of my ReadyNAS 3138.
dmesg shows this:
[ 3959.665535] usb 1-1.1: new high-speed USB device number 4 using ehci-pci
[ 3959.832285] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 3959.832414] scsi host11: usb-storage 1-1.1:1.0
[ 3960.834519] scsi 11:0:0:0: Direct-Access     Seagate  Expansion HDD    1801 PQ: 0 ANSI: 6
[ 3960.835322] sd 11:0:0:0: Attached scsi generic sg4 type 0
	[ 3979.695568] sd 11:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 3979.696058] sd 11:0:0:0: [sde] 19532873727 512-byte logical blocks: (10.0 TB/9.09 TiB)
[ 3979.696063] sd 11:0:0:0: [sde] 4096-byte physical blocks
[ 3979.697160] sd 11:0:0:0: [sde] Write Protect is off
[ 3979.697167] sd 11:0:0:0: [sde] Mode Sense: 47 00 00 08
[ 3979.698198] sd 11:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3979.699707] sd 11:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 3979.767812]  sde: sde1 sde2
[ 3979.769307] sd 11:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 3979.771691] sd 11:0:0:0: [sde] Attached SCSI disk
[ 3981.607617] nfsd: last server has exited, flushing export cache
[ 3981.649436] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 3981.649464] NFSD: starting 90-second grace period (net ffffffff88d782c0)
In the backup howto it is stated that the preferred format is ext4.  The notes at the bottom say that one should try NTFS or FAT32 if the disk is not showing up.
Since this is a brand new disk I would like to make sure that I can use it with my NAS as I otherwise may still return it.
So my questions are:
  • Can this disk be used?
  • Which format shall I use?
  • How shall I format it, can I use a command line directly on the NAS?
    (see dmesg info above)
Thanks a lot in advance.
Message 1 of 3
Accepted Solutions
Sandshark
Sensei
Re: Connect 10TB USB drive to ReadyNAS 3138
The ReadyNAS does not natively support EXFAT, but I understand you can install exfat-fuse and exfat-utils via SSH.  Since my backup is to other NAS, I've not tried it myself.
Message 3 of 3
All Replies
Guru
Personally I disagree with that advice for backup.  If your PCs can't read the backup, then it isn't worth much.  So I recommend choosing a format you can read on your other PCs.  NTFS can be read and written by Windows, and read by Mac.
If you have a Windows PC, I would format it there.  I'd start by going into the windows disk manager, and delete any partitions that are on the drive.  Then create a new one, and initialize it.  Format using NTFS (as noted above).
Message 2 of 3
Sandshark
Sensei
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 548 views
  • 1 kudo
  • 3 in conversation
Announcements
