- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting Readynas Duo RND 2150 to router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Team
Please I have the Readynas Duo RND2150 v2 but some members have let me know its actually version 1.Please I am trying to connect to my home router D-Link dwr-921E router.Router IP address is set to 192.168.1.1 while Readynas IP address is set to 192.168.1.90 with subnet and gateway to the D-Link's IP address.I still can not access my readynas.Please is the something I am not doing right.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting Readynas Duo RND 2150 to router
Do you mean that you cannot access the NAS web UI, or do you mean that you cannot access the files using file explorer?
Did you have access before, and then suddenly lost it? If so, did something change on the network (new router, new PC, etc)?
Best not to create confusion on this point. Once you know what you have, just call it that.
The original Duo (v1)
- runs 4.1.x firmware
- says ReadyNAS Duo on the front panel
- often has a v2 label on the back or bottom (indicating a minor hardware revision).
The Duo v2
- runs 5.3.x firmware
- says ReadyNAS Duo v2 on the front panel
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephen
well its my first time connecting the readynas via a router.I have been able to access it via a web browser UI or via windows explorer and also Raidar.Please tell me.are all the settings ok.what could be wrong with my configuration.Because when I disconnect and then set my pc LAN IP to 192.168.1.XX I am able to reach the readynas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What address is the router assigning to your PC?
Have you tried just setting the NAS to use DHCP instead of assigning it a static IP address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have not tried that yet.I was hoping to use a static IP since my router or network runs on a static IP but not DHCP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you saying that the router doesn't support dhcp?
The goal here is to re-establish connectivity, then you can change the NAS IP configuration any way you want.
