× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Copy instead of move from external storage?
AndreasKa
Tutor
Hi All, I'm copying a load of data onto my 314 via the eSATA connection.
The default function is moving the data so that the external disk doesn't contain the data after it's complete.
Is there a way to copy the data instead so i have a backup on the original disk?
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: Copy instead of move from external storage?
How are you trying to copy the data? Using Windows Explorer? Some other method?
Message 2 of 6
AndreasKa
Tutor
it's an external drive plugged into the eSATA connection of the NAS.
Then i'm using the WebUI -> shares screen to browser the external drive then drag the folder/files from the external drive to a share on the NAS.
Dragging and dropping is, by default a copy operation in Windows so I assumed it would be the same but the data is no longer on the external drive
Message 3 of 6
Guru
If you right-click on the folder you will see "copy". After you click it, paste will appear when you right-click.
Message 4 of 6
AndreasKa
Tutor
Thanks Stephen, i'll try that next time. Just not used to using right-click in browser apps.
One would think though that they would keep the normal 'copy s default' methodology.
Message 5 of 6
mdgm-ntgr
Thanks Andreas.
I have passed on your request.
I agree that copying data between volumes is much safer than simply moving.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1571 views
  • 0 kudos
  • 3 in conversation
Announcements
