- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CrashPlan Fatal Java error after update to OS 6.6.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded OS yesterday and now CrashPlan is crashing.
# A fatal error has been detected by the Java Runtime Environment: # # SIGBUS (0x7) at pc=0x00007fa30bd09460, pid=26003, tid=140338276411136 # # JRE version: Java(TM) SE Runtime Environment (8.0_72-b15) (build 1.8.0_72-b15) # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.72-b15 mixed mode linux-amd64 compressed oops) # Problematic frame: # V [libjvm.so+0x70c460] jvm_define_class_common(JNIEnv_*, char const*, _jobject*, signed char const*, int, _jobject*, char const*, unsigned char, Thread*)+0x100 # # Core dump written. Default location: /usr/local/crashplan/core or core.26003
If I manually start it from the CLI and then check status:
root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine start Starting CrashPlan Engine ... Using standard startup OK root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine status CrashPlan Engine (pid 30330) is running. root@NAS:/usr/local/crashplan/bin# ./CrashPlanEngine status ./CrashPlanEngine: line 116: cannot create temp file for here-document: No space left on device CrashPlan Engine is stopped.
root@NAS:/usr/local/crashplan/bin# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.6G 2.2G 42% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 6.0M 2.0G 1% /run
tmpfs 986M 2.7M 984M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/md127 11T 5.6T 5.4T 52% /data
/dev/md127 11T 5.6T 5.4T 52% /home
/dev/md127 11T 5.6T 5.4T 52% /apps
Any ideas?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CrashPlan Fatal Java error after update to OS 6.6.1
Having the same issue. no luck finding a resolution yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which firmware did you update from? That would show in initrd.log
- Mark as New
- Bookmark
- Subscribe
- Permalink
for me updated from 6.6.0 where it was fine to 6.6.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which services are you running?
Do you have any apps or other packages installed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
DDClient
Plex Media Server
SMBPlus
Crashplan which is the one not working now.
Shares are using SMB, AFP and DLNA
AV is running too
I dont use snapshots.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just noticed this. I disabled AV to see if i can get this going.
Wed Feb 1 2017 17:30:38
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libjavafx_font_pango.so. Please delete the infected file soon if automatic delete setting is not enabled.
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libkcms.so. Please delete the infected file soon if automatic delete setting is not enabled.
Wed Feb 1 2017 17:30:37
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libgstreamer-lite.so. Please delete the infected file soon if automatic delete setting is not enabled.
Wed Feb 1 2017 17:29:22
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libprism_common.so. Please delete the infected file soon if automatic delete setting is not enabled.
Wed Feb 1 2017 17:29:21
Wed Feb 1 2017 17:26:20
Wed Feb 1 2017 17:26:19
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libawt.so. Please delete the infected file soon if automatic delete setting is not enabled.
Wed Feb 1 2017 17:08:36
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libjavafx_iio.so. Please delete the infected file soon if automatic delete setting is not enabled.
Wed Feb 1 2017 17:03:08
System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /usr/local/crashplan/jre/lib/amd64/libawt_xawt.so. Please delete the infected file soon if automatic delete setting is not enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, disabling AV Is worth a try. There are some fixes for AV that are automatically applied within a week (you can force it to happen sooner by rebooting) and some further ones coming in the next update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any one get this working again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had fun getting it all reinstalled and the client setup again but it is working once again. THANKS
