- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Credentials for backup from PC and laptop to ReadyNas 102
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two computers - laptop and PC. Both have Windows 10. I need to make backup from laptop to ReadyNas and from PC to ReadyNas. It works properly, but there is one problem with PC which I can't solve. Backup is possibly only if sharing protected password is OFF in Windows. In laptop it works (I entered credentials) but I can't find out what for credentials are there. Can anybody help me solve this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Credentials for backup from PC and laptop to ReadyNas 102
you chould be able to see the credential you are using in the laptop by running the windows credential manager. You won't see the password of course, but you will see the username.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Because on laptop it works and on my PC doesn't, so I tried in Credential manager to change step by step all logins, but my backup worked all the time. When I changed login in my backup job, it stopped working. So I do not know which credentials are really used by backup to fix it in my PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this a backup job on NAS? Or a backup program running on the PC? If the latter, what program is it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is backup job on NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I was thinking the other way around.
I think the next step is to try and access the PC share from the laptop, and sort out the permissions that way.
Are you using local accounts with PIN disabled on the PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection from laptop to PC doesn't work. Internal network from PC to NAS with credentials works OK. ReadyCloud from PC to NAS doesn't work with credentials ON. When credentials are OFF it works OK. I have noticed, that only when I change login in USER ACCOUNT it has influence on backup job. When I do the same from credential manager it has no influence on backup job. At least I know what for credential I am writing in backup job. I do not use local accounts with PIN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you wanting to back up with ReadyCloud Sync or are you sharing a folder on the PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I prefer to make back up of some folders from PC to NAS from time to time, and I would like to know why it doesn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are using frontview backup, then you need to share a folder on the PC with Windows filesharing, and use the proper Windows PC credentials in the NAS backup job.
The simplest way to troubleshoot the PC side of things is to attempt to access the PC from another Windows machine (in this case your laptop), and make sure that it works. Earlier in the thread you said that didn't work. So solving that is the first step.
FWIW, It's easier to back up up using software on the PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suppose that it may be because of settings in network cards in PC. I have network configured as follows: Acces to internet is by Router. Router is connected to Hub by cable. NAS and PC are connected to Hub by cables. Only laptop is connected by WiFi to Router. So I need some time to find out how to set up network cards to make it run. Thank you very much for your assistance and helpful advices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you give us the manufacturer/model name for the hub and router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router is especially manufactured for NETIA it is named NETIASPOT.
Hub is TL-SG1005D
Network cards in my PC-
Leaf Networks Adapter and
Intel(R) 82567LM-3 Gigabit Network Connection
I hope it may be useful
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Leaf adapter is a virtual adapter - there is no actual leaf network card. Leaf Networks invented the ReadyCloud technology and were eventually bought by Netgear. So the leaf "adapter" is just software that looks like a network card that is part of ReadyCloud.
Anyway, I think the issue is in the way the PC is set up. You should be able to access the shared folders in the PC from the laptop.
This guide includes information on setting up the shared PC folders: http://kb.netgear.com/app/answers/detail/a_id/29754
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved. Reason was simple but time consuming. I have changed user name using:
>Control panel>User accounts>User Accounts>Change your Account name..
It was not enough for the system, which always had seen old user name, though I had seen everywhere new user name. Then I changed user name using:
>Computer management>Users>Users.
It was enough for the system and now my backup works OK
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to know, thx for posting the solution. I'm glad you are running now.
