× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Dead Disks Readynas 2100
msmolyar
Follower
Hi,
Have a Readynas 2100 with 4x3TB WD Red drives. Had a drive show up dead on Frontview. After replacing and resync, still showing as dead, and now 3 of the 4 drives are showing as dead. The logs are below. Any help on clearing this is greatly appreciated. Volumes still accessible.
enclosure.log:
temp!!1!!status=ok::descr=50.0C/122.0F::expected=0-80C/32-176F
temp!!2!!status=ok::descr=25.0C/77.0F::expected=0-65C/32-149F
fan!!1!!status=ok::descr=4272RPM::type=SYS1
fan!!3!!status=ok::descr=5357RPM::type=SYS2
ups!!1!!status=not_present::descr=Not present
volume!!1!!status=warn::descr=Volume C: RAID Level X2, Not redundant. A disk failure will render this volume dead.; 6109 GB (73%) of 8326 GB used
disk!!1!!status=ok::descr=Channel 1: WDC WD30EFRX-68EUZN0 2794 GB, 27C/80F
disk!!2!!status=ok::descr=Channel 2: WDC WD30EFRX-68EUZN0 2794 GB, 0C/32F
disk!!3!!status=ok::descr=Channel 3: WDC WD30EFRX-68EUZN0 2794 GB, 0C/32F
disk!!4!!status=ok::descr=Channel 4: WDC WD30EFRX-68EUZN0 2794 GB, 0C/32F
model!!0!!mode=pro::descr=ReadyNAS 2100::arch=x86
initrd.log:
[2010/12/23 00:23:27] Factory default initiated due to new disks (no RAID, no partitions)!
[2010/12/23 00:36:45] Updated from RAIDiator to 4.2.15.
[2013/09/11 19:04:49] Updated from RAIDiator 4.2.15 to 4.2.24.
[2019/05/11 13:16:05] Updated from RAIDiator 4.2.24 to 4.2.31.
mdstat.log:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md4 : active raid5 sda7[0] sdd7[4] sdc7[2] sdb7[1]
2930252352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md3 : active raid5 sda6[5] sdd6[7] sdc6[6] sdb6[4]
2930253888 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md2 : active raid5 sda5[6] sdc5[7] sdb5[5]
2916120576 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UUU_]
md1 : active raid6 sda2[6] sdd2[4] sdc2[7] sdb2[5]
1048448 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU]
md0 : active raid1 sda1[6]
4193268 blocks super 1.2 [4/1] [U___]
unused devices: <none>
Thanks,
Mike
Message 1 of 2
Guru
Re: Dead Disks Readynas 2100
Both of these aren't right.  md2 is part of your data volume (it looks like you started with 1 TB drives, then expanded to 2 TB, and finally to 3 TB).
md0 is the operating system, and it should be RAID-1 with all four disks.
I suggest backing up the data, and then do a factory default - rebuilding the NAS and restoring data from the backup.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 333 views
  • 0 kudos
  • 2 in conversation
Announcements
