- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Deleting Snapshots - ReadyNAS102
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone,
I noticed that i was running out of disk space on my ReadyNAS, and when i checked i found that Snapshots were taking up over 2TB.
I went into the settings for that folder, and noticed this.
So even though the folder thinks there's over 2TB of Snapshot data, the number of snapshots is zero. If i look at the timeline i also don't see any Snapshots. Also, if i navigate to the snapshots folder it's empty.
These are the settings...
(Note : I changed the snapshot schedule to Never in the hope i could reclaim the space. It was set to weekly before that).
So my question is : Where is this data hiding, and how can i delete it to reclaim the space?
Cheers,
Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Deleting Snapshots - ReadyNAS102
Please send in your logs (see the Sending Logs link in my sig).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thanks for the quick reply. Just mailed them.
Cheers,
Andrew
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your snapshots were not upgraded when you updated to 6.2.4 back in July last year.
As a result they are not showing up in the UI.
I have sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you are not comfortable with providing remote access you have a few options.
1. If you are comfortable with SSH you could do:
# touch /.force_snapshots_upgrade # systemctl restart readynasd
This should upgrade the snapshots which would then allow you to delete them
or 2. You could backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup. Considering your system was setup on 6.0.0 (the very first firmware release) I think this would be a good idea. We have added some filesystem improvements which are not required, but still nice to have that can only be obtained by creating a new filesystem.
Note the issue that you have run into is a one-off upgrade issue that you ran into when updating to 6.2.4. You won't run into this problem again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
OK, great, thanks for your help 🙂
rgds,
Andy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have the same problem. My Readynas 104 is 5 TB. 3TB data. 2TB snapshots. Need help deleting the snapshots.
Thanks.
Cheers,
Erwin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Erwin,
I 'solved' it by copying all the files to another location, and doing a factory reset on the drive.
Then set everything up again, and copy the files back.
cheers,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks mdgm and AndyEd.
Cheers,
Erwin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
erldumlao, please run a balance on your volume and then once that has completed run a defrag.
I would suggest scheduling a defrag and balance to run weekly (at different times). You should schedule these to run at times when the NAS is being used lightly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do. Thanks again mdgm. Cheers!
