× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Difference in available storage space between WebGUI and Finder(AFP)
martin9911
Running 6.5
A couple of weeks ago I removed a "private time machine" allocating roughly 500Gb. The avaialabe storage in the WebGUI differs about 500Gb compared to what I can see in Finder, mounting a AFP-share.
Any idéas?
/Martin
Model: RN31400|ReadyNAS 300 Series 4- Bay
Message 1 of 15
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Difference in available storage space between WebGUI and Finder(AFP)
The NAS uses base 2 (like most PCs) whereas the Mac uses base 10. So you will get a larger number on your Mac but the amount of free storage is the same.
Also the Time Machine tab won't let you set a quota that is as large as all of the remaining space (it's not advisable to completely fill a volume).
Message 12 of 15
All Replies
Guru
Try running a balance
Message 2 of 15
mdgm-ntgr
What numbers do each report? And how much space is on the volume?
Message 3 of 15
martin9911
A balance did not fix it...
Message 4 of 15
martin9911
I´m doing a huge sorting of my data, all across my computers, external drives and the NAS.
This problem came when i removed a private time machine and I´ll soon be doing it again.
Can I fix this some way and how do I remove private time machine the right way so this does not happen again?
/Martin
Message 5 of 15
mdgm-ntgr
You may wish to update to 6.5.2.
Can you also send in your logs (see the Sending Logs link in my sig)?
Message 6 of 15
martin9911
Upgraded to 6.5.1, which is the latest available update for me.
I have found differences also within webgui.
Se attached files.
Sending you logs soon.
Message 7 of 15
martin9911
Logs are sent! 😄
Message 8 of 15
martin9911
I´m about to remove another "private timemachine". This time not 300 Gb but 1,5TB. Last time removed it I got an the difference in available data at the size of the removed "private timemachine"
I do want to fix that and I don´t want it to happen again.
So how is the best way to remove a "private timemachine"?
Message 9 of 15
mdgm-ntgr
If you go to https://<nasname>/admin/browse.html#path=%2Fdata%2F.timemachine
where <nasname> is the hostname or I.P. of the NAS do you see the Time Machine data still there for the deleted user?
Message 10 of 15
martin9911
No, removed time machine user does not show at all.
Message 11 of 15
mdgm-ntgr
Message 12 of 15
martin9911
So it's just a coincidence that the size of my deleted time machine matches with base 2 vs base 10?
Even though I never seen any difference in available space before?
Message 13 of 15
mdgm-ntgr
Base 2 to Base 10 conversion would be e.g.
1GiB (base 10) = 1024 ^ 3 / 1000 ^ 3 GB (base 2)
Disk manufacturers and Macs use base 10 whereas most PCs use base 2. PCs tend to call GiB, GB.
Message 14 of 15
martin9911
That´s not the case for me. Using your formula and to my current numbers:
NAS Webgui 2,95TB equals 3,021TB. Finder shows 3,24TB.
EDIT: I stand corrected! I was wrong, mdgm was right!
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2890 views
  • 0 kudos
  • 3 in conversation
Announcements
