× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Differing performance Laptop (Win10Pro) + Desktop (Win7Pro)
Daf1
Tutor
I'm experiencing different performance levels on my Laptop (Win 10 Pro, connected via USB3 Ethernet adapter) and Desktop (Win 7 Pro, onboard NIC - Z68X-UD5-B3 motherboard : LAN = Realtek RTL8111E chip (10/100/1000 Mbit))
ReadyNAS 104, X-RAID 5, OS 6.4.2
Laptop NAS Performance tester 1.7
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on Y: 5 times...
Iteration 1:     52.85 MB/sec
Iteration 2:     52.11 MB/sec
Iteration 3:     52.43 MB/sec
Iteration 4:     50.37 MB/sec
Iteration 5:     51.47 MB/sec
Average (W):     51.85 MB/sec
Running a 400MB file read on Y: 5 times...
Iteration 1:     57.51 MB/sec
Iteration 2:     55.13 MB/sec
Iteration 3:     57.13 MB/sec
Iteration 4:     59.38 MB/sec
Iteration 5:     56.92 MB/sec
Average (R):     57.22 MB/sec
Desktop
Running warmup...
Running a 400MB file write on Z: 5 times...
Iteration 1: 40.64 MB/sec
Iteration 2: 40.96 MB/sec
Iteration 3: 40.70 MB/sec
Iteration 4: 40.06 MB/sec
Iteration 5: 39.75 MB/sec
Average (W): 40.42 MB/sec
Running a 400MB file read on Z: 5 times...
Iteration 1: 48.38 MB/sec
Iteration 2: 49.40 MB/sec
Iteration 3: 47.66 MB/sec
Iteration 4: 48.29 MB/sec
Iteration 5: 48.29 MB/sec
Average (R): 48.40 MB/sec
ReadyNAS 104, Laptop + desktop on 9K MTU
Cat 5 cable all around.
Testing via mapped network drive on both.
Network adapter settings all the same except a few that aren't on the other :
Desktop
energy efficient ethernet - enabled
green ethernet - enabled
interrupt moderation - enabled
receive buffers - 512
receive side scaling - enabled
shutdown wake-on-lan - enabled
transmit buffers - 128
Laptop
vlan id - not present
wake on link change - enabled
wake on magic packet - enabled
I don't know enough about net hardware to know what these really mean.
Have recently re-installed Windows7 on the desktop - but the desktop performance has always been similar - although via drag+drop does seem to have slowed - Windows shows 30MB rather than 40MB/s it did before.
Have swapped over the cables going to laptop to desktop + re-run - same result on the desktop.
Could it just be hardware ? I find it hard to believe since speeds are well below Gb.
Some OS difference ?
One of the above settings ?
TIA
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 11
Accepted Solutions
Daf1
Tutor
Re: Differing performance Laptop (Win10Pro) + Desktop (Win7Pro)
A late update to this.
Just updated my desktop to Windows 10 (just before the free upgrade cut-off) - had a few issues post upgrade (network iffy - needed to put in IP/DNS manually) and USB3 chipset drivers - but after setting jump frames to 9K - the desktop now gets the same performance as the laptop i.e. ~50MB/s
So likely a OS/network driver type issue.
Message 11 of 11
All Replies
Guru
What MTU sizes are set up on the NAS and the two PCs?  (Look at the "Jumbo Packet" setting on the PCs?)
Message 2 of 11
Daf1
Tutor
All three on 9K MTU Jumbo Files
Message 3 of 11
Daf1
Tutor
Ran RAIDar on desktop so has the LEAF adapter, not on the laptop.
Message 4 of 11
Guru
What happens if you disable the leaf adapter on the desktop?
Also, it might be worth testing w/o jumbo frames, and see how the numbers compare.
Message 5 of 11
Daf1
Tutor
Desktop - disabled Leaf ADapter, no reboot
Running warmup...
Iteration 1: 40.86 MB/sec
Iteration 2: 40.68 MB/sec
Iteration 3: 40.33 MB/sec
Iteration 4: 40.50 MB/sec
Iteration 5: 40.18 MB/sec
Average (W): 40.51 MB/sec
Iteration 1: 47.84 MB/sec
Iteration 2: 48.21 MB/sec
Iteration 3: 47.98 MB/sec
Iteration 4: 47.89 MB/sec
Iteration 5: 48.67 MB/sec
Average (R): 48.12 MB/sec
Deskstop - Jumbo frames : Disabled
ReadyNAS 104 MTU : 1500 (I believe this is "disabled")
no reboot suggested by either
Running warmup...
Iteration 1: 37.02 MB/sec
Iteration 2: 36.99 MB/sec
Iteration 3: 36.44 MB/sec
Iteration 4: 36.32 MB/sec
Iteration 5: 36.96 MB/sec
Average (W): 36.74 MB/sec
Iteration 1: 41.38 MB/sec
Iteration 2: 41.85 MB/sec
Iteration 3: 40.71 MB/sec
Iteration 4: 41.02 MB/sec
Iteration 5: 39.64 MB/sec
Average (R): 40.92 MB/sec
Message 6 of 11
Guru
thx - you should probably re-enable JF and the leaf adapter.
What disks are in the laptop and the desktop?
Message 7 of 11
Daf1
Tutor
Laptop
Dell XPS 13
i7-5500U
8Gb Ram
256Gb SSD
Desktop
- self build
i7-2700k
16Gb Ram
Disks:
OS + NAS test drive : 1Tb Samsung 840 Evo SSD
Additional :
- Old 1Tb Samsung HDD 7200rpm
- 2x WD Green in RAID 1
Discs controlled by AHCI in RAID configuration - Intel RST
Message 8 of 11
Guru
So in both cases, NasTester was downloaded (and run) from an SSD drive?
Do you see any packet loss on the connection?  For instance, downloading logs before/after the test and looking in network_settings.log?
Message 9 of 11
Daf1
Tutor
Yup - both running off the main/OS SSD
Message 10 of 11
Daf1
Tutor
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3515 views
  • 1 kudo
  • 2 in conversation
Announcements
