Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Duo V2 Stupid thing i did now no drive is detected #24526070
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
07:34 AM
2015-01-13
07:34 AM
Hey all,
Need some urgent help, Please bare with me if I explain it not the best as English is not my first language.
I have a Netgear Readynas Duo V2 with slot 1 as the main hard drive always worked no problems accessed it via raidar firmware version was 4.4??? it was password protected by myself all good.
Today I decided to install a new blank second hard drive in slot 2.
Stupid thing I did was I removed slot 1 working one completely out from the Nas and just inserted the slot 2 new drive and created the new raid volume which happened to update my firmware to 5.3 something as well in the whole process. All good finished had new slot 2 now as new volume etc.
So I decided to take slot 2 new one out and wanted to use my original one in slot 1 as before, well was that a big mistake.
All blue lights are working ok slot 1 is solid blue but slot 2 is obviously blinking as no drive is in that slot.
The Error message im getting is readynas specified network cannot be longer available
also when I hit browse in the raidar I get a windows network error windows cant access xxxxxx.2.13xxx/media. check the spelling of the name otherwise there might be a problem with youe network etc
it would seem I have resynced everything in slot 2 now instead of my slot 1 main drive.
please help
please help
Message 1 of 16
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
08:05 AM
2015-01-13
08:05 AM
Re: ReadyNas Duo V2 Stupid thing i did now no drive is detec
First, check if you have a Duo v1 or Duo v2 on this link: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Do you have a back up of all the data stored on the old disk1?
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
09:01 AM
2015-01-13
09:01 AM
What I'd do is to insert the original drive back and perform an OS reinstall.
But first, check if you really have a v2 Duo.
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
09:31 AM
2015-01-13
09:31 AM
the front say ReadyNas Duo V2
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
09:32 AM
2015-01-13
09:32 AM
barcode wrote: the front say ReadyNas Duo V2
Have you fully read the link I have provided you?
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-13
05:04 PM
2015-01-13
05:04 PM
Re: Duo V2 Stupid thing i did now no drive is detected #2452
Yes i have read your post and its 100% Duo V2
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
08:54 AM
2015-01-14
08:54 AM
Kindly read the previous post of Nhellie in this thread and kindly do it.
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
09:00 AM
2015-01-14
09:00 AM
barcode,
remove the new disk, insert the original disk and perform OS reinstall (So that the FW on the flash and disk will match). Follow the instructions on boot menu codes on the link below:
http://kb.netgear.com/app/answers/detai ... JjbQ%3D%3D
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
09:28 AM
2015-01-14
09:28 AM
The normal boot should do that automatically if the format on the disk doesn't match. But it does no harm.
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
09:37 AM
2015-01-14
09:37 AM
What I'm thinking is since the NAS updated its FW after installing a new disk, the old disk and the FW on the flash would not match.
My interpretation was:
1. He removed the old (original disk) with an older FW version.
2. Inserted a new disk, created a new volume and updated the FW.
3. Removed new disk, inserted the old disk back and it is not detected anymore.
So I'm thinking FW mismatch. 🙂
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
10:06 AM
2015-01-14
10:06 AM
That's true, but the normal boot usually handles that without the need for a manual OS reinstall. By default, if the firmware in the flash is not the same as the disk, the firmware on the disk is updated.
Nhellie wrote: What I'm thinking is since the NAS updated its FW after installing a new disk, the old disk and the FW on the flash would not match.
Though trying a manual OS reinstall from the boot menu should do no harm.
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
05:08 PM
2015-01-14
05:08 PM
hi all thanks for your inputs I have tried reinstalling the OS as instructed.
It starts to say in the Raidar window updating slot 1 is solid blue light all ok, after the updating it just comes up with file system check 100% I don't see any firmware version this file system check 100% just stays like this wont change I have left it on like this for 24h straight and still wont change.
is there a way I can downgrade my firmware back to 4.1.3 or what ever I have before?
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
05:14 PM
2015-01-14
05:14 PM
So the filesystem check has hung. There could be issues with the filesystem
Do you have a backup?
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
05:20 PM
2015-01-14
05:20 PM
mdgm wrote: So the filesystem check has hung. There could be issues with the filesystem
no backup that's why i'm in a panic. Can I remove the disk and just plug it in a windows pc to read the drive and then grab all my data off it then I can start over. guessing the nas has transferred the disk it too its own language and the pc wont read it
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-14
05:40 PM
2015-01-14
05:40 PM
Well you could contact support and purchase support for them to look into it.
Or perhaps try the boot menu option skipping the volume check (risky) and see if you do that you can get it to boot so you can copy your data off.
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-01-17
05:23 AM
2015-01-17
05:23 AM
Just wanted to give everyone a little update on how I solved the problem in case future users loose or accidently muck up the readynas duo v2 in anyway.
As I had no backup I knew the files on the original drive were not destroyed, so I installed the not so famous (too me) Ubuntu OS as it reads all ext2 ext3 ext4 data. Recovered all my data using test drive with photorec. Once all was recovered I formatted the slot 1 drive along with slot 2 drive in one hit as a complete format as a new readynas system, then obviously installed all my data back.
All working now!
thanks all for your comments.
All working now!
Message 16 of 16
