× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Dustbin
Rororuru
Dustbin
Good morning,
is it possible to create a dustbin to recover deleted files, as we have in windows for example?
Thank you for your help.
Model: RN102|ReadyNAS 100 Series
Message 1 of 3
Guru
Re: Dustbin
Snapshots have some similar properties, so you might want to look into those first.  With snapshots enabled, you can right-click on a file or folder in Windows, and you will have an option to restore previous versions that are in the snapshots.
It is possible to create a network recycle bin for a share, but it requires the use of ssh.  That does have support implications - if you do this incorrectly and do damage,  Netgear will deny support.  The method is outlined here: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-...
Note you'd need to add a section to the addons.conf file for each share that needs a recycle bin.
Message 2 of 3
Rororuru
Re: Dustbin
Thank you for your answer. I will try. But it is unfortunate that ready Nas do not offer a simple way to recover a file deleted by error.
By the way, in a first try, I could not  activate snapshots.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 657 views
  • 1 kudo
  • 2 in conversation
Announcements
