× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Enabling SMB2 on ReadyNAS Pro
thecleartech
Attempted to enable SMB2 per the instructions linked below; namely, added the line min protocol = SMB2 to the [Gobal] section of the /etc/samba/smb.conf file on the NAS. Then restarted the NAS, but upon attempting to connect to the NAS from a Windows 10 PC (start > run \\<IPAddress>) the error displayed below still persists
I did connect via SSH again to the NAS again to confirm that the line "min protocol = SMB2" is still present in the smb.conf file; it was. Any advise would be appreciated, thank you.
SMB2 on ReadyNAS via SSH
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/SMB1/m-p/1261727
Model: ReadyNAS RNDP4000|ReadyNAS Pro 4 Chassis only
Message 1 of 8
TeknoJnky
Hero
Re: Enabling SMB2 on ReadyNAS Pro
while not necessarily secure, you can re-enable smb v1 on windows
https://www.google.com/search?q=enable+smb+1+windows+10
ReadyNAS 528X, Pro 6, ProBusiness, Ultra 4, NV+
Message 2 of 8
thecleartech
We're an IT provider - we can't and won't, in good conscience, advise that anyone do that.
Incidentally, if the error msg displayed at teh client (above) is not displaying, it's "You can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack."
Message 3 of 8
Guru
As pointed out on your other thread, your other option is to convert the Pro to run OS-6.  That is not supported by Netgear, but many have done it.  The process requires reformatting the drives, so all data would need to be reloaded from backup.
You can see more information on the process here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Lost-contact-with-NAS-after-upgradi...
Message 4 of 8
thecleartech
My hope (expectation, based on others' results) is that SMB2 support could be enabled with RAIDiator 4.2.3 .... or is that not available in these legacy versions of firmware?
Message 5 of 8
Guru
There is an experimental configuration flag that could be set - I haven't tried it, and don't know how buggy that early implementation is.
There is an old post here that describes how one person made this work:  https://community.netgear.com/t5/New-ReadyNAS-Users-General/Support-for-SMB2/m-p/1007083#M9336
smb.conf does have a warning in it, saying that it is autogenerated.  I don't know when the system regenerates though.
Message 6 of 8
TeknoJnky
Hero
regarding smb on 4.x Netgear really needs to provide a better supported solution for this as the issue is only going to keep reoccuring as more people upgrade to new versions of windows over time.
Message 7 of 8
Sandshark
Sensei
I do hope you left off a digit in the version.  4.2.3 is ancient.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 5021 views
  • 1 kudo
  • 4 in conversation
Announcements
