× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Erreur can_overcommit
Wil31
Tutor
Hi everybody,
My ReadyNAS 104 version 6.9.2 didn't respond. I rebooted it.
One hour after Boot process, only one message displays : can_overcommit+20
I don't have SSH or Web access, only ping.
What can I do ?
Model: RN104|ReadyNAS 100 Series
Message 1 of 11
Accepted Solutions
Guru
Re: Erreur can_overcommit
One option is to use paid support (my.netgear.com).
Can you boot the NAS in read-only mode using the boot menu?  See pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Message 3 of 11
All Replies
Wil31
Tutor
deleted
Message 2 of 11
Guru
Message 3 of 11
Wil31
Tutor
Thanks for your fast answer.
I will test your solution.
Message 4 of 11
Wil31
Tutor
I booted in "Read only" mode.
The NAS displays "Resync 33,34 %".
I can access Web interface.
Message 5 of 11
Guru
Good.  You should confirm that you have access to your data.
Wait for the resync to complete.  While that's going on:
  • Most importantly, you should be backing up the data on your NAS before you reboot.  If you need USB drives to do that, then purchase them right away.  Back up the most critical data before then (as much as you can).
  • click on the volume setting wheel and see if quotas are enabled.  If they are, disable them.
  • It would also be good to disable services that you don't need or can live without.  For instance, the antivirus service.
Message 6 of 11
Wil31
Tutor
The remaining time is 70 hours !
May I update firmware to 6.9.3 to avoid any problem ?
Message 7 of 11
Guru
Not now.  Wait for the resync.
Message 8 of 11
Wil31
Tutor
OK. I don't use antivirus.
I will follow your advices and come back here when resync and backup are done.
Many thanks.
Message 9 of 11
Wil31
Tutor
Hi StephenB,
Good News !
After RAID reconstructing, I could access all my datas then I made backups.
After rebooting in normal mode, all is ok.
I updated firmware 6.9.2 to 6.9.3 with success.
Thank you for your help.
Message 10 of 11
Guru
Great!  Thx for posting the outcome.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1989 views
  • 0 kudos
  • 2 in conversation
Announcements
