Orbi WiFi 7 RBE973
Reply
Expanding Storage on RN3138 Question
NARKOSIS
Good afternoon,
Our company is looking to expand our 3TBx4 NAS.  We are running RAID-X (Raid5).  The documentation mentions the drives are hot-swap enabled.  Does that mean we can just remove (say) the fourth drive, install a 6TB drive and its good to go?  Do all of the drives need to be the same size?
Message 1 of 7
Accepted Solutions
Guru
Re: Expanding Storage on RN3138 Question
Basically yes.
You should make sure your backup is up to date before manipulating disks, as the array isn't redundant during the RAID resync, and the process will fail if there are latent disk issues.
Then hot-swap the first disk and wait for the resync to complete.
When it does, hot-swap the second, and wait for it.  There will be two resyncs needed (the second one will likely be called "reshaping".  So be sure it is complete before moving on to the third.
Also, the volume won't expand until the second disk is replaced and fully resynced.  The third and fourth disk upgrades will also expand.
The capacity rule is "sum the disks and subtract the largest".  That will give you the size in TB (1000*1000*1000*1000 bytes).  However, the NAS actually reports TiB (1024*1024*1024*1024).  Google can convert this for you btw - for example, try entering 12 TB in TiB into the Google search bar.
As is hopefully clear from the first response, no.
Personally I'd upgrade only two of the drives, and upgrade them with larger models.  That allows upgrades to be done more cheaply later (and often more cheaply now).
For instance, upgrading four disks to 6 TB Ironwolf Pros would cost about $720 USD and gain you 9 TB of capacity.  Upgrading two disks to 12 TB Ironwolf Pros would actually cost you a bit less at the moment (about $650 USD) - and you'd end up with the same volume size.  Plus when you need to upgrade again, you can replace one of the 3 TB drives with another 12 TB one, and gain another 9 TB.  A lot cheaper than upgrading all four every time.
That's just an example, obviously if you prefer different disks the pricing will be different.  But I do recommend using either NAS purposed (WDC Red or Seagate Ironwolf) or enterprise-class drives.
Message 2 of 7
All Replies
Guru
Basically yes.
Message 2 of 7
NARKOSIS
Thanks for the detailed explanations/recommendations!  Is there a preferred/recommended order to replace them?  Or does it matter? IE, Replacing the first on the Left->Right (1,2,3,4), or Right->Left (4,3,2,1)?  And yes, we are looking at the Ironwolf drives.
Message 3 of 7
Guru
It doesn't matter.  If the existing drives weren't purchased at the same time, then perhaps replace the oldest first?
Message 4 of 7
Sandshark
Sensei
Oldest or any showing SMART errors first.
Message 5 of 7
NARKOSIS
None of them are (relatively) old and/or failing.  All 4 were purchased/installed at the same time about 1 1/2yrs ago.  We just require more storage space given that we are getting into 3D scan/point cloud data and each project is about 50-100GB in size.
Message 6 of 7
Guru
Then it doesn't matter which ones you upgrade,
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1721 views
  • 0 kudos
  • 3 in conversation
Announcements
