Orbi WiFi 7 RBE973
Reply
External USB Drives on OS6 - How to run filesystem check.
steveoelliott
Luminary
Hi all,
On OS6, I have noticed that when attaching an external drive (this one came from a 4.2 OS so is ext4) there is no option to run a file system check. On 4.2 you could click check filesystem.
Is there no way to do this on OS6? If not why was it removed?
I know that I can run fsck from the CLI but i'd rather do it from the GUI.
Thanks...
Message 1 of 2
Guru
Re: External USB Drives on OS6 - How to run filesystem check.
Perhaps another suggestion for the exchange.
One OS4 idea that I liked was the ability to send a WoL packet before a backup job started.  I wish that one was put back.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3030 views
  • 0 kudos
  • 2 in conversation
Announcements
