× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
FLAC rips
dsteak
FLAC rips
There seems to be a plethora of programs to convert WAV files to FLAC. Are any better than others? My intent is to stream my files over Sonos. So far I've looked at Total Recorder and Media Monkey. Using Total Recorder, I noticed there is a compression setting 1 thru 10, defaulting to 5. I'm starting to read up, but was wondering if anyone had a quick reference on the topic.
Thanks.
Message 1 of 3
Xophile
Re: FLAC rips
You should definately check out this:
http://blowfish.be/eac/Setup/setup1.html
Exact Audio Copy is freeware (read donateware) and works flawlessly. DbPoweramp is an alternative but you will have to purchase a license for it.
Use the accuraterip addon for EAC to make sure your rips are 100% accurate.
The compression setting does what it says, I go with maximun compression - it takes a little bit of extra time while converting but it does not bother meat all.
I have 400+ purchased original CDs perfectly ripped with EAC and I play them through my ReadyNAS 4 on Squezzebox/Xbox etc. Works like charm!
Good luck!
Message 2 of 3
Xophile
Re: FLAC rips
dsteak:
How did it go? 😉
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2232 views
  • 0 kudos
  • 2 in conversation
Announcements
