- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FTP with AD user auth not listing directory properly
- Mark as New
- Bookmark
- Subscribe
- Permalink
OS 6.9.1, AD Authentication, ProFTPD 1.3.6, client and 3220 NAS on same subnet.
Setting up a new FTP share for a network scanner. Testing with FileZilla client and WinSCP and getting the same results: When anonymous FTP is enabled, everything works fine. When I disable anon FTP and enable user auth, I can log in but not see the share called Scans. Instead, I see a directory listing like this:
/accounts;UNIX.mode=0770;UNIX.owner=32890;UNIX.ownername=scanner; Scans
There is nothing obvious in proftpd.log:
2017-12-26 14:10:45,349 mod_tls/2.7[12952]: TLS/TLS-C requested, starting TLS handshake
2017-12-26 14:10:45,353 mod_tls/2.7[12952]: client supports secure renegotiations
2017-12-26 14:10:45,353 mod_tls/2.7[12952]: TLSv1.2 connection accepted, using cipher ECDHE-RSA-AES256-GCM-SHA384 (256 bits)
2017-12-26 14:10:45,378 mod_tls/2.7[12952]: Protection set to Private
FTP Network access is set to the "scanner" user only. Under the File Acess tab, I've set the folder owner to "scanner" and folder group to the primary group of the scanner account, as well as tried the default access settings.
I'm not sure where to go next. TIA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: FTP with AD user auth not listing directory properly
Try a different client or try changing your user's primary group to one that doesn't contain a space character.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
