× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Fanoverride stopped working after upgrade to 6.4.0
Calder
Guide
When I upgraded to 6.4.0, the fanoverride stopped working.  Anyone else experiencing this?  Would 6.4.X down the road be able to work with the fanoverride scripts again?  Of course, if the OS itself can give an option to have a check-box to let users choose to have a normal fan speed mode or an increased fan speed mode would be best.
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: Fanoverride stopped working after upgrade to 6.4.0
Overriding the fan speed using the fanoverride script is an unsupported hack.
You could try this:
# echo "FAN_MODE=cool" >> /etc/default/services
# systemctl restart readynasd
You can do quiet, balanced or cool
EDIT: OOPS. Forgot the second > (thought about it then forgot to put it in). Thanks michaelarnauts.
Message 2 of 3
michaelarnauts
DON'T DO THAT COMMAND. IT WILL ERASE YOUR CONFIG!!
You should do this. Note the two >>'s. This will add FAN_MODE=cool to the end of the file instead of replacing it.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2241 views
  • 1 kudo
  • 3 in conversation
Announcements
