- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware 6.6.0 & 6.6.1 error in Diag report from Raidar
- Mark as New
- Bookmark
- Subscribe
- Permalink
After Firmware 6.6.0 and 6.6.1 the text below is reported in the Diagnostics report from RAIDar
Dated and timed at ever boot:-
- home.mount: Directory /home to mount over is not empty, mounting anyway.
This only appeared after update to 6.6.0 from 6.5.2 units running 6.5.2 or 6.5.1 do not report this error only devices running 6.6.x
NAS Sytems are working correctly.
Any ideas as I do not want to update my other 8 production boxes until I understand the implications of this error.
rimmerhg
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
We don't have an ETA yet. But those warnings can be safely ignored. If you'd prefer fixing it up from the command line, I can post instructions.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware 6.6.0 & 6.6.1 error in Diag report from Raidar
Hi rimmerhg,
Did you get a screenshot of the diagnostic message you have encountered? If yes, kindly post it.
Since you mentioned the NAS is working correctly by the time you have encountered the diagnostic message, what is the model of the NAS you are referring to? Is it still working just fine as of now?
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS RN314 4x 1TB WD RED Raid 6 This is a copy of the screen data...... Successfully completed diagnostics System Logs 2017-01-15 11:18:27: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-15 07:00:41: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-14 14:20:18: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-14 07:00:42: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-13 20:29:43: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-13 18:30:57: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-01-13 18:26:16: home.mount: Directory /home to mount over is not empty, mounting anyway. This was obtained by clicking on the diagnostics button on the RAIDar app The unit has firmware 6.6.1 and this error only appears when the unit has booted the times correspond to power on times. This has only appeared on my 6.6.x units after the 6.6.x update my other 314 units running 6.5.x do not show it only my 6.6.x units. The unit is working fine I just checked after the upgrade as this is good practise after upgrade so I can record it in the change logs for my clients. Can anyone advise or is this a bug introduced in 6.6.x firmware. (Is it something I should be concerned about ? as I would like to update my 10 production 314 & 316 Units to 6.6.x Kind regards, rimmerhg
- Mark as New
- Bookmark
- Subscribe
- Permalink
This means that at some point the /home mount point was not mounted but the system wrote some data under /home anyway so there's some data on the root volume that should be on the data volume.
Can you send in your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Logs sent to mgdm
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also seeing this on my Pro 4 running OS 6.6.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not actually a new issue -- it's just an additional diagnostic test that was added in 6.6.1. It's most likely just am empty /home/admin directory on the root filesystem, which is harmless except for this message. It'll be cleaned up automatically in the next firmware release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for this information, when is the next firmware date approximately scheduled for ?
Kind regards,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Skywalker wrote:We don't have an ETA yet. But those warnings can be safely ignored. If you'd prefer fixing it up from the command line, I can post instructions.
Yes please
- Mark as New
- Bookmark
- Subscribe
- Permalink
# mount --bind / /mnt # rmdir /mnt/home/* # umount /mnt
