× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Firmware update and ReadyNAS File Systems
e__e
I would like to know which File Systems in the ReadyNAS OS are not impacted by a firmware update.
Probably
/data
/media
/home
/apps
But is
/root
also not overwritten by a firmware update?
(there are scripts in it I'd like to keep)
Message 1 of 4
mdgm-ntgr
NETGEAR Employee Retired
Re: Firmware update and ReadyNAS File Systems
I would suggest you make sure that the backup of your custom scripts is up to date before installing a firmware update.
Any file not listed under /etc/default/config may well be overwritten on a firmware update by a file with the same name.
Message 2 of 4
e__e
Thanks.
So it is indeed very unlikely there is a file name collision in /root...
Message 3 of 4
mdgm-ntgr
Still with custom scripts it is possible that depending on how it is done you may encounter unpredictable behaviour. So best to make sure your backup is up to date before doing a firmware update.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2551 views
  • 0 kudos
  • 2 in conversation
Announcements
