× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
FrontView Loading Improperly - EEPROM Issue
tfrederick74656
Hi everyone! I've been a lurker here for quite some time, and this community has been especially helpful! Finally ran into something I couldn't tackle, though -
I'm having the the issues described in these threads, where the EEPROM data is overwritten when USB recovery is used:
community.netgear.com/t5/Using-your-ReadyNAS/Unable-to-access-frontview/m-p/946896
community.netgear.com/t5/Using-your-ReadyNAS/Frontview-webpage-loading-partial/m-p/962775
community.netgear.com/t5/Using-your-ReadyNAS/Frontview-problem-readynas-pro-4/m-p/1058765
I was hoping somebody could help me with this. I'm more than capable of working with Linux, but none of the other posts have included the solution publically.
Also - I don't generally run any of the stock netgear software/firmware, instead running CentOS as a deduplicated iSCSI storage target, but recently I've been considering selling my unit (not right now, but I wanted to ensure that I COULD return it to stock IF I wanted to). I see that some of the others with this problem have had a one-time fix for this issue. Since I play with custom software on this unit all the time, I'm sure it will happen again. If it's possible to get the solution, rather than just have someone apply the fix, that would definitely be preferable.
Thanks!
Model: RNDP600E |ReadyNAS Pro Pioneer Edition|EOL
Message 1 of 4
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: FrontView Loading Improperly - EEPROM Issue
Check your PM inbox.
Message 3 of 4
All Replies
mdgm-ntgr
The main reason the solution is not public is that the fix is specific to each device. The fix is different for any two customer devices even if they are the same model.
Message 2 of 4
mdgm-ntgr
Message 3 of 4
tfrederick74656
You rock, thank you so much for all the help!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2592 views
  • 0 kudos
  • 2 in conversation
Announcements
