Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Frontview doesn't save changes
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-20
10:13 AM
2013-09-20
10:13 AM
My ReadyNAS Ultra 2 boot and I can access it via Frontview but, no configuration changes can be saved.
I have read about similar problems in other forums
http://www.readynas.com/forum/viewtopic.php?f=20&t=65366&p=363109
http://www.readynas.com/forum/viewtopic.php?f=7&t=51711
I can go through the dialogue to upgrade the firmware or to restore a configuration back-up but, it does not seem to save anything. There is no log. I did an OS reinstall but, the problem persists.
It sounds to the OS is out of space but, there are no instructions to free up space for it. The status lights on the unit and in Raidar 4.2.24 show everything normal.
I have tried to connect via SSH (Putty) but, I have not been able to connect successfully.
It has been running fine for a couple of years with no problems.
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-22
03:29 AM
2013-09-22
03:29 AM
Re: Frontview doesn't save changes
go to backup tab to clean all backup logs, I hope this will be able to free up your OS space.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-22
04:25 AM
2013-09-22
04:25 AM
You can also delete the system logs. Do you use ReadyDLNA?
To use ssh you need to enable it on the ultra by installing the addon here: http://www.readynas.com/?p=4203 You want the x86 version of course.
Then when logging in with putty, use "root" as the user and your admin password.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-22
04:31 AM
2013-09-22
04:31 AM
There was a "crash-backup" folder that filled up the 4 GB OS partition. Perhaps you have installed Crashplan but did not configure it properly.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-22
03:05 PM
2013-09-22
03:05 PM
I have crash-backup on my C drive. I believe the cache location can also be set, if so it should also be kept off the OS partition. (Sorting that is still on my to-do list!)
mdgm wrote: There was a "crash-backup" folder that filled up the 4 GB OS partition. Perhaps you have installed Crashplan but did not configure it properly.
Message 5 of 5
