Orbi WiFi 7 RBE973
Reply
Fulltextindexing PDFs?
BastianW
Hello,
is there a way to autofullindex my PDFs on my ReadyNAS and use a kind of webpage to search in the results?
regards
Bastian
Message 1 of 4
OOM-9
NETGEAR Expert
Re: Fulltextindexing PDFs?
There is not an option for this in the default search for the PDF indexing.
You were mentioning a webpage part... Were you thinking of a type of web page? There are a number of addons that get a webpage started that may have more options for you.
What ReadyNAS do you have?
Message 2 of 4
BastianW
The idea was that there exist a plugin for the ReadyNAS which can perform a fulltext on all PDFs and this result can be searched then via a webpage. But it looks like the current plugins didn´t offer that. Maybe I will write then a short plugin (with PHP output) which can do that.
Message 3 of 4
BastianW
Just a small update. Maybe somebody else may like the idea too. I´m currently checking if it would be possible to use Joomla and the component JiFile from here (http://www.isapp.it/en/jifile-home) so that joomla could index my PDFs on my ReadyNAS. That would allow my to check my content then as I have a lot of documents and knowledge stored on my NAS which isn´t so easy to check if I need something from it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1068 views
  • 0 kudos
  • 2 in conversation
Announcements
