Orbi WiFi 7 RBE973
Reply
Ghost files - Re-scan scheduling
woto
Hey Guys
I read a post on here about ghost files that a TV can see using DLNA, that you have to rescan to get rid of them.
So my question is there a way of of scheduling a rescan on the DLNA rather than it set to Auto as i am finding this a problem that it doesn’t scan an update enough, as i move files and delete them quite allot
Regards
John
Model: RN104|ReadyNAS 100 Series
Message 1 of 9
bedlam1
Prodigy
Re: Ghost files - Re-scan scheduling
The ReadyNAS DLNA system has a default scan time of 900 seconds (every 15 minutes), this can be changed using SSH and say, putty, at /etc/minidlna.conf you can also change the "friendly" name of your DLNA server.
Message 2 of 9
woto
thanks for the info,
this seems strange as its over 15mins that i have checked, i had a look at it lastnight and again thismorning and they where still there
Message 3 of 9
Guru
The auto scan is likely better at adding new files than it is at removing deleted files.
One possibility is to be able to set up a schedule for a full rescan.  That would be a new feature, so maybe post it to the idea exchange.
Message 4 of 9
woto
i did a manual rescan on the DLNA, i found it got rid of the deleted files but i have noticed that one of my folders is missing, i checked it again after a hour or so but its still not there, might do a rescan again see if appears after that.
Does anyone know if Twonky can be installed on the ReadyNas i used to use that on my pc before i got a NAS and that seemed to work really well streaming direct to the TVs
Message 5 of 9
bedlam1
Prodigy
Have a look at "Apps" then "Available Apps" on your NAS GUI, "Twonky Server" should be there, but I have never used it personally
Message 6 of 9
woto
i did look in the apps GUI,  but i didn't see it there, i presumed that it had to be installed manually
Message 7 of 9
bedlam1
Prodigy
Oh OK, it is there for X86 processors (which I have) but you have ARM, sorry cannot advise you further then
Message 8 of 9
Guru
The other option for OS-6 NAS is plex - which also includes a DLNA server.  You download it from plex and manually install it.
It's possible that your issue is due to a corrupt media file that is crashing the scan.  Try downloading the log zip file from the web ui, and looking in upnp-av.log.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1854 views
  • 0 kudos
  • 3 in conversation
Announcements
