Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Grow 3200 beyond 14TB?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
01:07 PM
2013-01-29
01:07 PM
Before I jump into this project. We are bumping up against the 14TB limit of the 3200. We've scoped out the drives and even a weekend on which to do this. Correct me if I am wrong, but if we do the following we should be okay:
1. Add 2TB into all twelve drive bays, wait for sync to complete (we'll be doing this over a period of about a week or so)
2. Double check to ensure our other 3200 has the duplicated data of our primary 3200
3. Once the file verification is complete, factory reset the primary 3200, which should move us past the 14TB barrier and closer to 20TB (usable). Right?
4. Copy over the duplicated data back to its original home
5. Repeat process on the secondary NAS
Am I right about this?
Message 1 of 17
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
01:16 PM
2013-01-29
01:16 PM
Re: Grow 3200 beyond 14TB?
sounds about right.
if you are using the default x-raid2 dual redundancy, then it will be ~18tb (10x 1850gb or so)
Message 2 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
01:35 PM
2013-01-29
01:35 PM
TeknoJnky wrote: sounds about right.
That should be enough...okay, figured I would double check. You know, measure twice cut once sort of thing.
If you were doing this, would you go with 2TB or 3TB?
Message 3 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
02:05 PM
2013-01-29
02:05 PM
You can only go 2TB with the 3200.
You could at most do a small mix, the first four channels will support 3TB, but not the remaining eight.
Same applies to the 4200 v1. They made a 4200 v2 that supported 3TB across the board, but didn't do a 3200 v2.
Message 4 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
02:11 PM
2013-01-29
02:11 PM
well, I am using 4tb drives in my devices, but I don't think that it matters for the 3200...
with the 3200, it only supports 3tb+ drives on the first 4 channels, the remaining 8 max out at 2tb, this is due to the LSI sata controller doesn't have the necessary large drive support.
So if you expect to need over ~18tb in the future, you may need to start considering another solution.
Message 5 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-29
02:38 PM
2013-01-29
02:38 PM
You could get ~20TB dual redundancy with 4x4TB + 6x2TB, though using 4TB today means going off the HCL.
Message 6 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-01
09:29 AM
2013-02-01
09:29 AM
chirpa wrote: You can only go 2TB with the 3200.
Good to know. That's what I'll do, first four as 3TB and the remaining as 2TB. Thanks for the heads up.
Message 7 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-02
06:28 PM
2013-02-02
06:28 PM
NO, do not do this.
You can not add smaller disks after larger disks.
Message 8 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-02
10:26 PM
2013-02-02
10:26 PM
He would have to have 4x3T,8x2T in there with a factory default, or all 2TB and replace the first four with 3TB.
The LSI controller on the v1 12-bays controls the last 8 channels, it did not support 3TB. The Intel controller for the first four disks did.
Message 9 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
01:40 PM
2013-02-15
01:40 PM
So I did just that, put it 1-4 as 3TB and 5-12 as 2TB. Did a factory reset, after several hours of rebooting the max I can get it to be is 18TB. It seems like it wants to grow bigger (it keeps telling me it can grow further). So I reboot the device to allow it to expand, but then after a few hours of resync, I get another message saying "failed to grow volume" or something to that extent. If I look at the volume it shows that all of the drives' space is allocated. If I am doing my math right, I should be getting 22TB-24TB, no? Or am I just at the 3200's maximum size and it won't grow to anything past 18TB?
Here's the expansion log:
Thoughts?
[2013/02/14 08:49:10 3095] Boot, handle mutiple expand_md
[2013/02/14 08:49:11 3096] STAGE_CHECK: saved my_pid 3096 in check mode.
[2013/02/14 08:49:11 3096] RAID MODE: 1, sn=
[2013/02/14 08:49:11 3096] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 08:49:11 3096] Current file system status: ext4
[2013/02/14 08:49:11 3096] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 08:49:11 3096] X_level: 6
[2013/02/14 08:49:11 3096] /usr/sbin/expand_md
[2013/02/14 08:49:11 3096] MD degraded 0, bg_job 1, boot 1
[2013/02/14 08:49:11 3096] Open /var/log/frontview/.known_cfgdir failed, create a new dir.
[2013/02/14 08:49:11 3096] LINE 4775: exec command: mkdir /var/log/frontview/.known_cfgdir
[2013/02/14 08:49:11 3096] Failed to read last good COD.
Open config file:: No such file or directory
[2013/02/14 08:49:11 3096] access 1, new_disk 0, fs 4
[2013/02/14 08:49:11 3096] Disk configuration mis-matching with online configuration, will do update...
[2013/02/14 08:49:11 3096] ++++Write 1957072 byte to configuration++++
[2013/02/14 08:49:11 3096] /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 08:49:11 3096] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 08:49:11 3096] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:11 3096] LINE 7839: exec command: sgdisk -p /dev/sde | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 08:49:12 3096] /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 08:49:12 3096] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 08:49:12 3096] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:12 3096] LINE 7839: exec command: sgdisk -p /dev/sdf | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 08:49:12 3096] /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 08:49:12 3096] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:12 3096] LINE 7839: exec command: sgdisk -p /dev/sdg | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 08:49:12 3096] /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 08:49:12 3096] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:12 3096] LINE 7839: exec command: sgdisk -p /dev/sdh | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 08:49:12 3096] /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 08:49:12 3096] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:12 3096] LINE 7839: exec command: sgdisk -p /dev/sdi | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 08:49:12 3096] /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 08:49:12 3096] get disk /dev/sdj format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:12 3096] LINE 7839: exec command: sgdisk -p /dev/sdj | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 08:49:13 3096] /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 08:49:13 3096] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 08:49:13 3096] get disk /dev/sdk format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:13 3096] LINE 7839: exec command: sgdisk -p /dev/sdk | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 08:49:13 3096] /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 08:49:13 3096] get disk /dev/sdl format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:13 3096] LINE 7839: exec command: sgdisk -p /dev/sdl | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 08:49:13 3096] /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 08:49:13 3096] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:13 3096] LINE 7839: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 08:49:14 3096] /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 08:49:14 3096] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 08:49:14 3096] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:14 3096] LINE 7839: exec command: sgdisk -p /dev/sdb | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 08:49:14 3096] /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 08:49:14 3096] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:14 3096] LINE 7839: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 08:49:14 3096] /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 08:49:14 3096] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 08:49:14 3096] LINE 7839: exec command: sgdisk -p /dev/sdd | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 08:49:14 3096] STAGE_WIPE: Clean my_pid 3096
[2013/02/14 19:31:06 2551] Boot, handle mutiple expand_md
[2013/02/14 19:31:07 2552] STAGE_CHECK: saved my_pid 2552 in check mode.
[2013/02/14 19:31:07 2552] RAID MODE: 1, sn=
[2013/02/14 19:31:07 2552] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 19:31:08 2552] Current file system status: ext4
[2013/02/14 19:31:08 2552] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 19:31:08 2552] X_level: 6
[2013/02/14 19:31:08 2552] /usr/sbin/expand_md
[2013/02/14 19:31:08 2552] MD degraded 0, bg_job 1, boot 1
[2013/02/14 19:31:08 2552] Read 1957072 byte from configuration
[2013/02/14 19:31:08 2552] Disk configuration matching with online configuration.
[2013/02/14 19:31:08 2552] STAGE_WIPE: Clean my_pid 2552
[2013/02/14 19:53:14 4000] STAGE_CHECK: saved my_pid 4000 in check mode.
[2013/02/14 19:53:14 4000] RAID MODE: 1, sn=
[2013/02/14 19:53:14 4000] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 19:53:14 4000] Current file system status: ext4
[2013/02/14 19:53:14 4000] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 19:53:14 4000] X_level: 6
[2013/02/14 19:53:14 4000] /usr/sbin/expand_md -a super
[2013/02/14 19:53:14 4000] MD degraded 0, bg_job 0, boot 0
[2013/02/14 19:53:14 4000] ++++Write 1957072 byte to configuration++++
[2013/02/14 19:53:14 4000] /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 19:53:14 4000] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:53:14 4000] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:14 4000] LINE 7839: exec command: sgdisk -p /dev/sde | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 19:53:14 4000] Sgdisk /dev/sde partition to file Error. rc = -1
[2013/02/14 19:53:14 4000] /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 19:53:14 4000] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:14 4000] LINE 7839: exec command: sgdisk -p /dev/sdf | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 19:53:14 4000] Sgdisk /dev/sdf partition to file Error. rc = -1
[2013/02/14 19:53:14 4000] /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 19:53:14 4000] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:14 4000] LINE 7839: exec command: sgdisk -p /dev/sdg | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 19:53:14 4000] Sgdisk /dev/sdg partition to file Error. rc = -1
[2013/02/14 19:53:14 4000] /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 19:53:14 4000] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:14 4000] LINE 7839: exec command: sgdisk -p /dev/sdh | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 19:53:14 4000] Sgdisk /dev/sdh partition to file Error. rc = -1
[2013/02/14 19:53:14 4000] /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 19:53:14 4000] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:14 4000] LINE 7839: exec command: sgdisk -p /dev/sdi | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdi partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 19:53:15 4000] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:53:15 4000] get disk /dev/sdj format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdj | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdj partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 19:53:15 4000] get disk /dev/sdk format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdk | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdk partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 19:53:15 4000] get disk /dev/sdl format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdl | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdl partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 19:53:15 4000] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 19:53:15 4000] Sgdisk /dev/sda partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 19:53:15 4000] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdb | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdb partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 19:53:15 4000] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdc partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 19:53:15 4000] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] LINE 7839: exec command: sgdisk -p /dev/sdd | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 19:53:15 4000] Sgdisk /dev/sdd partition to file Error. rc = -1
[2013/02/14 19:53:15 4000] LINE 4939: exec command: ps -ef | grep -v expand_md > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 19:53:15 4000] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] /dev/sde used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] /dev/sdf used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] /dev/sdg used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] /dev/sdh used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:53:15 4000] /dev/sdi used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] /dev/sdj used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] /dev/sdk used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] /dev/sdl used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:53:15 4000] /dev/sda used/total/partitioned = 1953512504/2930266584/1953512504, 60000000
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sde 1953512504
[2013/02/14 19:53:15 4000] /dev/sda:2(2-gpt 1-mbr) correct used blocks 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdf 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdg 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdh 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdi 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdj 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdk 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdl 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sda 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdb 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdc 1953512504
[2013/02/14 19:53:15 4000] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdd 1953512504
[2013/02/14 19:53:15 4000] exec command: Selected: 8 total=2930266584 used/resv=1953512504/60000000 free=976754080, cl_at=0, property4k=1
[2013/02/14 19:53:15 4000] LINE 4304: exec command: lvdisplay | grep /dev/c/ > /var/log/frontview/.V_E.lvdisplayout
[2013/02/14 19:53:15 4000] STAGE_WIPE: Clean my_pid 4000
[2013/02/14 19:58:45 2586] Boot, handle mutiple expand_md
[2013/02/14 19:58:46 2587] STAGE_CHECK: saved my_pid 2587 in check mode.
[2013/02/14 19:58:46 2587] RAID MODE: 1, sn=
[2013/02/14 19:58:46 2587] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 19:58:46 2587] Current file system status: ext4
[2013/02/14 19:58:46 2587] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 19:58:46 2587] X_level: 6
[2013/02/14 19:58:46 2587] /usr/sbin/expand_md
[2013/02/14 19:58:46 2587] MD degraded 0, bg_job 0, boot 1
[2013/02/14 19:58:46 2587] Read 1957072 byte from configuration
[2013/02/14 19:58:46 2587] Disk configuration matching with online configuration.
[2013/02/14 19:58:46 2587] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:58:46 2587] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sde used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdf used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdg used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdh used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdi used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdj format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdj used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdk format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdk used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sdl format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sdl used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 19:58:46 2587] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] /dev/sda used/total/partitioned = 1953512504/2930266584/1953512504, 60000000
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sde 1953512504
[2013/02/14 19:58:46 2587] /dev/sda:2(2-gpt 1-mbr) correct used blocks 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdf 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdg 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdh 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdi 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdj 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdk 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdl 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sda 1953512504
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdb 1953512504
[2013/02/14 19:58:46 2587] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdc 1953512504
[2013/02/14 19:58:46 2587] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] Checking: want expand from /dev/sda 1953512504, already in use /dev/sdd 1953512504
[2013/02/14 19:58:46 2587] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:46 2587] exec command: Selected: 8 total=2930266584 used/resv=1953512504/60000000 free=976754080, cl_at=0, property4k=1
[2013/02/14 19:58:47 2587] LINE 4304: exec command: lvdisplay | grep /dev/c/ > /var/log/frontview/.V_E.lvdisplayout
[2013/02/14 19:58:47 2587] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:58:47 2587] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:47 2587] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:47 2587] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:47 2587] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:47 2587] disk /dev/sda (MBR-1 GPT-2 MIX-3 MISC-0xFF):2
[2013/02/14 19:58:47 2587] LINE 7626: exec command: sgdisk -f /dev/sda > /var/log/frontview/.V_E.avail_offset.sav
[2013/02/14 19:58:47 2587] get dev /dev/sda available start offset is 3907025073
[2013/02/14 19:58:47 2587] LINE 7670: exec command: rm -fr /var/log/frontview/.V_E.avail_offset.sav
[2013/02/14 19:58:47 2587] LINE 7626: exec command: sgdisk -E /dev/sda > /var/log/frontview/.V_E.avail_offset.sav
[2013/02/14 19:58:47 2587] get dev /dev/sda available end offset is 5860533134
[2013/02/14 19:58:48 2587] LINE 7670: exec command: rm -fr /var/log/frontview/.V_E.avail_offset.sav
[2013/02/14 19:58:48 2587] LINE 7839: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.V_E.temp_pt.sav
[2013/02/14 19:58:48 2587] /dev/sda index 1: start 64 end 8388671
[2013/02/14 19:58:48 2587] /dev/sda index 2: start 8388672 end 9437247
[2013/02/14 19:58:48 2587] /dev/sda index 3: start 9437248 end 3907025072
[2013/02/14 19:58:48 2587] LINE 7593: exec command: rm -fr /var/log/frontview/.V_E.temp_pt.sav
[2013/02/14 19:58:48 2587] LINE 4036: exec command: sgdisk -g -a 8 -n 4:3907025073:5860529038 -t 4:FD00 /dev/sda
Information: Moved requested sector from 3907025073 to 3907025080 in
order to align on 8-sector boundaries.
Warning: The kernel is still using the old partition table.
The new table will be used at the next reboot.
The operation has completed successfully.
[2013/02/14 19:58:50 2587] LINE 7839: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.V_E.temp_pt.sav
[2013/02/14 19:58:50 2587] /dev/sda index 1: start 64 end 8388671
[2013/02/14 19:58:50 2587] /dev/sda index 2: start 8388672 end 9437247
[2013/02/14 19:58:50 2587] /dev/sda index 3: start 9437248 end 3907025072
[2013/02/14 19:58:50 2587] /dev/sda index 4: start 3907025080 end 5860529038
[2013/02/14 19:58:50 2587] LINE 7593: exec command: rm -fr /var/log/frontview/.V_E.temp_pt.sav
[2013/02/14 19:58:50 2587] new partition id:4 start:3907025080,end:5860529038,size:1953503959
[2013/02/14 19:58:50 2587] 008 /dev/sda,Z295BKXW,8, 0, 2930266584 1953512504 1953512504 MD_FULL 0
[2013/02/14 19:58:50 2587] partitions: 3 property: 4K
[2013/02/14 19:58:50 2587] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2013/02/14 19:58:50 2587] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2013/02/14 19:58:50 2587] 002 /dev/sda3, 8, 3, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 19:58:50 2587] clean /dev/sda at 3907025081 and 2930266572
[2013/02/14 19:58:50 2587] LINE 2746: exec command: dd of=/dev/sda if=/dev/zero seek=3907025081 bs=512 count=12
12+0 records in
12+0 records out
6144 bytes (6.1 kB) copied, 0.0250669 s, 245 kB/s
[2013/02/14 19:58:51 2587] LINE 2746: exec command: dd of=/dev/sda if=/dev/zero seek=5860529016 bs=512 count=22
22+0 records in
22+0 records out
11264 bytes (11 kB) copied, 0.0960107 s, 117 kB/s
[2013/02/14 19:58:51 2587] Create new partition in /dev/sdb
[2013/02/14 19:58:51 2587] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:58:51 2587] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:51 2587] disk /dev/sdb is GPT Format
[2013/02/14 19:58:51 2587] Create new partition 4 in /dev/sdb
[2013/02/14 19:58:51 2587] LINE 4116: exec command: sgdisk -g -a 8 -n 4:3907025080:5860529038 -t 4:FD00 /dev/sdb
[2013/02/14 19:58:53 2587] 009 /dev/sdb,Z295BM32,8, 16, 2930266584 1953512504 1953512504 MD_FULL 0
[2013/02/14 19:58:53 2587] partitions: 3 property: 4K
[2013/02/14 19:58:53 2587] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2013/02/14 19:58:53 2587] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2013/02/14 19:58:53 2587] 002 /dev/sdb3, 8, 19, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 19:58:53 2587] clean /dev/sdb at 3907025081 and 2930266572
[2013/02/14 19:58:53 2587] LINE 2746: exec command: dd of=/dev/sdb if=/dev/zero seek=3907025081 bs=512 count=12
12+0 records in
12+0 records out
6144 bytes (6.1 kB) copied, 0.0430511 s, 143 kB/s
[2013/02/14 19:58:53 2587] LINE 2746: exec command: dd of=/dev/sdb if=/dev/zero seek=5860529016 bs=512 count=22
22+0 records in
22+0 records out
11264 bytes (11 kB) copied, 0.0320897 s, 351 kB/s
[2013/02/14 19:58:53 2587] Create new partition in /dev/sdc
[2013/02/14 19:58:53 2587] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:58:53 2587] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:53 2587] disk /dev/sdc is GPT Format
[2013/02/14 19:58:53 2587] Create new partition 4 in /dev/sdc
[2013/02/14 19:58:53 2587] LINE 4116: exec command: sgdisk -g -a 8 -n 4:3907025080:5860529038 -t 4:FD00 /dev/sdc
[2013/02/14 19:58:55 2587] 010 /dev/sdc,Z295AW0P,8, 32, 2930266584 1953512504 1953512504 MD_FULL 0
[2013/02/14 19:58:55 2587] partitions: 3 property: 4K
[2013/02/14 19:58:55 2587] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2013/02/14 19:58:55 2587] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2013/02/14 19:58:55 2587] 002 /dev/sdc3, 8, 35, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 19:58:55 2587] clean /dev/sdc at 3907025081 and 2930266572
[2013/02/14 19:58:55 2587] LINE 2746: exec command: dd of=/dev/sdc if=/dev/zero seek=3907025081 bs=512 count=12
12+0 records in
12+0 records out
6144 bytes (6.1 kB) copied, 0.0230338 s, 267 kB/s
[2013/02/14 19:58:55 2587] LINE 2746: exec command: dd of=/dev/sdc if=/dev/zero seek=5860529016 bs=512 count=22
22+0 records in
22+0 records out
11264 bytes (11 kB) copied, 0.0284094 s, 396 kB/s
[2013/02/14 19:58:55 2587] Create new partition in /dev/sdd
[2013/02/14 19:58:55 2587] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 19:58:55 2587] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 19:58:55 2587] disk /dev/sdd is GPT Format
[2013/02/14 19:58:55 2587] Create new partition 4 in /dev/sdd
[2013/02/14 19:58:55 2587] LINE 4116: exec command: sgdisk -g -a 8 -n 4:3907025080:5860529038 -t 4:FD00 /dev/sdd
[2013/02/14 19:58:58 2587] 011 /dev/sdd,Z295AWD5,8, 48, 2930266584 1953512504 1953512504 MD_FULL 0
[2013/02/14 19:58:58 2587] partitions: 3 property: 4K
[2013/02/14 19:58:58 2587] 000 /dev/sdd1, 8, 49, 4194304 MD_FULL md=/dev/md0
[2013/02/14 19:58:58 2587] 001 /dev/sdd2, 8, 50, 524288 MD_FULL md=/dev/md1
[2013/02/14 19:58:58 2587] 002 /dev/sdd3, 8, 51, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 19:58:58 2587] clean /dev/sdd at 3907025081 and 2930266572
[2013/02/14 19:58:58 2587] LINE 2746: exec command: dd of=/dev/sdd if=/dev/zero seek=3907025081 bs=512 count=12
12+0 records in
12+0 records out
6144 bytes (6.1 kB) copied, 0.0327264 s, 188 kB/s
[2013/02/14 19:58:58 2587] LINE 2746: exec command: dd of=/dev/sdd if=/dev/zero seek=5860529016 bs=512 count=22
22+0 records in
22+0 records out
11264 bytes (11 kB) copied, 0.0444506 s, 253 kB/s
[2013/02/14 19:58:58 2587] LINE 448: exec command: echo "DONE_PARTITION" > /.os_V_E_continue
[2013/02/14 19:58:58 2587] New partitions added, need to reboot to continue, rebooting...
[2013/02/14 19:58:58 2587] STAGE_WIPE: Clean my_pid 2587
[2013/02/14 20:00:26 2609] Boot, handle mutiple expand_md
[2013/02/14 20:00:27 2610] STAGE_CHECK: saved my_pid 2610 in check mode.
[2013/02/14 20:00:27 2610] RAID MODE: 1, sn=
[2013/02/14 20:00:27 2610] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 20:00:27 2610] Current file system status: ext4
[2013/02/14 20:00:27 2610] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 20:00:27 2610] Adjust used size on /dev/sda Used/total/partitioned=2930266584/2930264483/2930264483, -(not used)976751979
[2013/02/14 20:00:27 2610] Adjust used size on /dev/sdb Used/total/partitioned=2930266584/2930264483/2930264483, -(not used)976751979
[2013/02/14 20:00:27 2610] Adjust used size on /dev/sdc Used/total/partitioned=2930266584/2930264483/2930264483, -(not used)976751979
[2013/02/14 20:00:27 2610] Adjust used size on /dev/sdd Used/total/partitioned=2930266584/2930264483/2930264483, -(not used)976751979
[2013/02/14 20:00:27 2610] X_level: 6
[2013/02/14 20:00:27 2610] /usr/sbin/expand_md
[2013/02/14 20:00:27 2610] MD degraded 0, bg_job 0, boot 1
[2013/02/14 20:00:27 2610] Read 1957072 byte from configuration
[2013/02/14 20:00:27 2610] Disk configuration matching with online configuration.
[2013/02/14 20:00:27 2610] Should do expand now...
[2013/02/14 20:00:27 2610] ===== Partition Entry (MD not used) =====
[2013/02/14 20:00:27 2610] ===== Partition Entry (Used by MD) =====
[2013/02/14 20:00:27 2610] 000 /dev/sde,9WM8750G,8, 64, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] partitions: 3 property: 4K
[2013/02/14 20:00:27 2610] 000 /dev/sde1, 8, 65, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sde2, 8, 66, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sde3, 8, 67, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 001 /dev/sdf,9WM89Q2E,8, 80, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdf1, 8, 81, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdf2, 8, 82, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdf3, 8, 83, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 002 /dev/sdg,9WM89PGW,8, 96, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdg1, 8, 97, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdg2, 8, 98, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdg3, 8, 99, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 003 /dev/sdh,9WM87KPZ,8, 112, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdh1, 8, 113, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdh2, 8, 114, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdh3, 8, 115, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 004 /dev/sdi,9WM866RG,8, 128, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdi1, 8, 129, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdi2, 8, 130, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdi3, 8, 131, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 005 /dev/sdj,9WM85TGY,8, 144, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdj1, 8, 145, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdj2, 8, 146, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdj3, 8, 147, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 006 /dev/sdk,9WM89PW3,8, 160, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdk1, 8, 161, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdk2, 8, 162, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdk3, 8, 163, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 007 /dev/sdl,9WM89LR3,8, 176, 1953514584 1953512504 1953512504 MD_FULL 0
[2013/02/14 20:00:27 2610] 000 /dev/sdl1, 8, 177, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdl2, 8, 178, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdl3, 8, 179, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 008 /dev/sda,Z295BKXW,8, 0, 2930266584 1953512504 2930264483 MD_PART 0
[2013/02/14 20:00:27 2610] partitions: 4 property: 4K
[2013/02/14 20:00:27 2610] 000 /dev/sda1, 8, 1, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sda2, 8, 2, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sda3, 8, 3, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 003 /dev/sda4, 8, 4, 976751979 NO_MD md=
[2013/02/14 20:00:27 2610] 009 /dev/sdb,Z295BM32,8, 16, 2930266584 1953512504 2930264483 MD_PART 0
[2013/02/14 20:00:27 2610] 000 /dev/sdb1, 8, 17, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdb2, 8, 18, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdb3, 8, 19, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 003 /dev/sdb4, 8, 20, 976751979 NO_MD md=
[2013/02/14 20:00:27 2610] 010 /dev/sdc,Z295AW0P,8, 32, 2930266584 1953512504 2930264483 MD_PART 0
[2013/02/14 20:00:27 2610] 000 /dev/sdc1, 8, 33, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdc2, 8, 34, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdc3, 8, 35, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 003 /dev/sdc4, 8, 36, 976751979 NO_MD md=
[2013/02/14 20:00:27 2610] 011 /dev/sdd,Z295AWD5,8, 48, 2930266584 1953512504 2930264483 MD_PART 0
[2013/02/14 20:00:27 2610] 000 /dev/sdd1, 8, 49, 4194304 MD_FULL md=/dev/md0
[2013/02/14 20:00:27 2610] 001 /dev/sdd2, 8, 50, 524288 MD_FULL md=/dev/md1
[2013/02/14 20:00:27 2610] 002 /dev/sdd3, 8, 51, 1948793912 MD_FULL md=/dev/md2
[2013/02/14 20:00:27 2610] 003 /dev/sdd4, 8, 52, 976751979 NO_MD md=
[2013/02/14 20:00:27 2610] Found leftover expansion actions DONE_PARTITION
, continue...
[2013/02/14 20:00:27 2610] Start second phase expansion
[2013/02/14 20:00:27 2610] LINE 4162: exec command: vgdisplay -c c > /var/log/frontview/.V_E.vgdisplayout ; lvdisplay -c c > /var/log/frontview/.V_E.lvdisplayout
[2013/02/14 20:00:28 2610] 0 vg= c lv= /dev/c/c
[2013/02/14 20:00:28 2610] 1 vg=r/w lv=c
[2013/02/14 20:00:28 2610] 2 vg=772 lv=3
[2013/02/14 20:00:28 2610] 3 vg=-1 lv=1
[2013/02/14 20:00:28 2610] 4 vg=0 lv=-1
[2013/02/14 20:00:28 2610] 5 vg=1 lv=1
[2013/02/14 20:00:28 2610] 6 vg=1 lv=38954860544
[2013/02/14 20:00:28 2610] 7 vg=-1 lv=297202
[2013/02/14 20:00:28 2610] 8 vg=0 lv=-1
[2013/02/14 20:00:28 2610] 9 vg=1 lv=0
[2013/02/14 20:00:28 2610] 10 vg=1 lv=0
[2013/02/14 20:00:28 2610] 11 vg=19487916032 lv=253
[2013/02/14 20:00:28 2610] 12 vg=65536 lv=0
[2013/02/14 20:00:28 2610] 13 vg=297362 lv=13
[2013/02/14 20:00:28 2610] 14 vg=297202 lv=14
[2013/02/14 20:00:28 2610] 15 vg=160 lv=15
[2013/02/14 20:00:28 2610] 16 vg=yoMbyP-4RXt-zDIM-ky5T-2rxT-QxS0-Pray9A
lv=16
[2013/02/14 20:00:28 2610] 17 vg=17 lv=17
[2013/02/14 20:00:28 2610] 18 vg=18 lv=18
[2013/02/14 20:00:28 2610] 19 vg=19 lv=19
[2013/02/14 20:00:28 2610] Partitions so far1: /dev/sda4
[2013/02/14 20:00:28 2610] LINE 4429: exec command: mdadm --misc --force --zero-superblock /dev/sda4
mdadm: Unrecognised md component device - /dev/sda4
[2013/02/14 20:00:28 2610] Partitions so far2: /dev/sda4 /dev/sda4
[2013/02/14 20:00:28 2610] Partitions so far: /dev/sda4
[2013/02/14 20:00:28 2610] Partitions so far1: /dev/sda4 /dev/sda4 /dev/sdb4
[2013/02/14 20:00:28 2610] LINE 4429: exec command: mdadm --misc --force --zero-superblock /dev/sdb4
mdadm: Unrecognised md component device - /dev/sdb4
[2013/02/14 20:00:28 2610] Partitions so far2: /dev/sda4 /dev/sda4 /dev/sdb4 /dev/sdb4
[2013/02/14 20:00:28 2610] Partitions so far: /dev/sda4 /dev/sdb4
[2013/02/14 20:00:28 2610] Partitions so far1: /dev/sda4 /dev/sdb4 /dev/sda4 /dev/sdb4 /dev/sdc4
[2013/02/14 20:00:28 2610] LINE 4429: exec command: mdadm --misc --force --zero-superblock /dev/sdc4
mdadm: Unrecognised md component device - /dev/sdc4
[2013/02/14 20:00:28 2610] Partitions so far2: /dev/sda4 /dev/sdb4 /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sdc4
[2013/02/14 20:00:28 2610] Partitions so far: /dev/sda4 /dev/sdb4 /dev/sdc4
[2013/02/14 20:00:28 2610] Partitions so far1: /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sdd4
[2013/02/14 20:00:28 2610] LINE 4429: exec command: mdadm --misc --force --zero-superblock /dev/sdd4
mdadm: Unrecognised md component device - /dev/sdd4
[2013/02/14 20:00:29 2610] Partitions so far2: /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sdd4 /dev/sdd4
[2013/02/14 20:00:29 2610] Partitions so far: /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sdd4
[2013/02/14 20:00:29 2610] LINE 4462: exec command: mdadm --create --run -e 1.2 --name=3 --homehost=003048FBCC70 /dev/md3 -f -c 64 -l 6 -n 4 /dev/sda4 /dev/sdb4 /dev/sdc4 /dev/sdd4
mdadm: array /dev/md3 started.
[2013/02/14 20:00:29 2610] LINE 4470: exec command: dd if=/dev/zero of=/dev/md3 bs=1024k count=1
1+0 records in
1+0 records out
1048576 bytes (1.0 MB) copied, 0.136335 s, 7.7 MB/s
Physical volume "/dev/md3" successfully created
[2013/02/14 20:00:29 2610] LINE 4495: exec command: pvcreate -ffy /dev/md3
[2013/02/14 20:00:29 2610] pvcreated
Volume group "c" successfully extended
[2013/02/14 20:00:30 2610] LINE 4515: exec command: vgextend c /dev/md3
[2013/02/14 20:00:30 2610] vgextended
[2013/02/14 20:00:30 2610] LINE 4162: exec command: vgdisplay -c c > /var/log/frontview/.V_E.vgdisplayout ; lvdisplay -c c > /var/log/frontview/.V_E.lvdisplayout
[2013/02/14 20:00:30 2610] 0 vg= c lv= /dev/c/c
[2013/02/14 20:00:30 2610] 1 vg=r/w lv=c
[2013/02/14 20:00:30 2610] 2 vg=772 lv=3
[2013/02/14 20:00:30 2610] 3 vg=-1 lv=1
[2013/02/14 20:00:30 2610] 4 vg=0 lv=-1
[2013/02/14 20:00:30 2610] 5 vg=1 lv=1
[2013/02/14 20:00:30 2610] 6 vg=1 lv=38954860544
[2013/02/14 20:00:30 2610] 7 vg=-1 lv=297202
[2013/02/14 20:00:30 2610] 8 vg=0 lv=-1
[2013/02/14 20:00:30 2610] 9 vg=2 lv=0
[2013/02/14 20:00:30 2610] 10 vg=2 lv=0
[2013/02/14 20:00:30 2610] 11 vg=21441413120 lv=253
[2013/02/14 20:00:30 2610] 12 vg=65536 lv=0
[2013/02/14 20:00:30 2610] 13 vg=327170 lv=13
[2013/02/14 20:00:30 2610] 14 vg=297202 lv=14
[2013/02/14 20:00:30 2610] 15 vg=29968 lv=15
[2013/02/14 20:00:30 2610] 16 vg=yoMbyP-4RXt-zDIM-ky5T-2rxT-QxS0-Pray9A
lv=16
[2013/02/14 20:00:30 2610] 17 vg=17 lv=17
[2013/02/14 20:00:30 2610] 18 vg=18 lv=18
[2013/02/14 20:00:30 2610] 19 vg=19 lv=19
[2013/02/14 20:00:30 2610] Facts:vg_total=327170,vg_alloc=297202,vg_free=29968,lv_new=29808,lv_total=%
[2013/02/14 20:00:30 2610] LINE 4374: exec command: lvextend /dev/c/c -l +29808
Extending logical volume c to 19.96 TB
Logical volume c successfully resized
[2013/02/14 20:00:30 2610] LINE 4555: exec command: /frontview/bin/volumescan &
[2013/02/14 20:00:30 2610] LINE 448: exec command: echo "DOING_F_RESIZE" > /.os_V_E_continue
[2013/02/14 20:00:31 2610] LINE 4249: exec command: resize2fs -pf /dev/c/c
resize2fs 1.42.3 (14-May-2012)
resize2fs: New size too large to be expressed in 32 bits
[2013/02/14 20:00:31 2610] Expand second phase error 10: resize2fs, err=0x100
[2013/02/14 20:00:31 2610] Second phase failed, will clean flags, no expansion for now.
[2013/02/14 20:00:31 2610] STAGE_WIPE: Clean my_pid 2610
[2013/02/14 23:17:01 4331] STAGE_CHECK: saved my_pid 4331 in check mode.
[2013/02/14 23:17:01 4331] RAID MODE: 1, sn=
[2013/02/14 23:17:01 4331] LINE 4591: exec command: lvs > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 23:17:01 4331] Current file system status: ext4
[2013/02/14 23:17:01 4331] LINE 5229: exec command: rm -fr /var/log/frontview/.V_E.*
[2013/02/14 23:17:01 4331] X_level: 6
[2013/02/14 23:17:01 4331] /usr/sbin/expand_md -a super
[2013/02/14 23:17:01 4331] MD degraded 0, bg_job 0, boot 0
[2013/02/14 23:17:02 4331] ++++Write 1957072 byte to configuration++++
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 23:17:02 4331] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 23:17:02 4331] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sde | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM8750G
[2013/02/14 23:17:02 4331] Sgdisk /dev/sde partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 23:17:02 4331] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdf | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89Q2E
[2013/02/14 23:17:02 4331] Sgdisk /dev/sdf partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 23:17:02 4331] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdg | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PGW
[2013/02/14 23:17:02 4331] Sgdisk /dev/sdg partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 23:17:02 4331] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdh | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM87KPZ
[2013/02/14 23:17:02 4331] Sgdisk /dev/sdh partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 23:17:02 4331] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdi | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM866RG
[2013/02/14 23:17:02 4331] Sgdisk /dev/sdi partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 23:17:02 4331] get disk /dev/sdj format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdj | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM85TGY
[2013/02/14 23:17:02 4331] Sgdisk /dev/sdj partition to file Error. rc = -1
[2013/02/14 23:17:02 4331] /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 23:17:02 4331] get disk /dev/sdk format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:02 4331] LINE 7839: exec command: sgdisk -p /dev/sdk | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89PW3
[2013/02/14 23:17:03 4331] Sgdisk /dev/sdk partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 23:17:03 4331] gpt sig:0,mbr sig:0,fake type:0
[2013/02/14 23:17:03 4331] get disk /dev/sdl format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] LINE 7839: exec command: sgdisk -p /dev/sdl | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/9WM89LR3
[2013/02/14 23:17:03 4331] Sgdisk /dev/sdl partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 23:17:03 4331] get disk /dev/sda format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] LINE 7839: exec command: sgdisk -p /dev/sda | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BKXW
[2013/02/14 23:17:03 4331] Sgdisk /dev/sda partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 23:17:03 4331] get disk /dev/sdb format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] LINE 7839: exec command: sgdisk -p /dev/sdb | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295BM32
[2013/02/14 23:17:03 4331] Sgdisk /dev/sdb partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 23:17:03 4331] get disk /dev/sdc format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] LINE 7839: exec command: sgdisk -p /dev/sdc | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AW0P
[2013/02/14 23:17:03 4331] Sgdisk /dev/sdc partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 23:17:03 4331] get disk /dev/sdd format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] LINE 7839: exec command: sgdisk -p /dev/sdd | grep '[0-9] ' > /var/log/frontview/.known_cfgdir/Z295AWD5
[2013/02/14 23:17:03 4331] Sgdisk /dev/sdd partition to file Error. rc = -1
[2013/02/14 23:17:03 4331] LINE 4939: exec command: ps -ef | grep -v expand_md > /var/log/frontview/.V_E.snapshotstat
[2013/02/14 23:17:03 4331] get disk /dev/sde format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sde used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdf format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdf used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdg format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdg used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdh format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdh used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdi format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdi used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdj format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdj used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] get disk /dev/sdk format is (GPT=2,MBR=1,MX=3,MISC=-1): 2
[2013/02/14 23:17:03 4331] /dev/sdk used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] /dev/sdl used/total/partitioned = 1953512504/1953514584/1953512504, 60000000
[2013/02/14 23:17:03 4331] /dev/sda used/total/partitioned = 2930264483/2930266584/2930264483, 60000000
[2013/02/14 23:17:03 4331] /dev/sdb used/total/partitioned = 2930264483/2930266584/2930264483, 60000000
[2013/02/14 23:17:03 4331] /dev/sdc used/total/partitioned = 2930264483/2930266584/2930264483, 60000000
[2013/02/14 23:17:03 4331] /dev/sdd used/total/partitioned = 2930264483/2930266584/2930264483, 60000000
[2013/02/14 23:17:03 4331] Not enough disk for a new array, drives with free space: 0, X_level:6
[2013/02/14 23:17:03 4331] STAGE_WIPE: Clean my_pid 4331
Thoughts?
Message 10 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-15
02:44 PM
2013-02-15
02:44 PM
I don't understand anything of that log, but I will make a guess;
because of the mixed sized disks, there are 2 raid layers, 12x 2tb (minus 4tb in dual redunancy), then balance of the 3tb drives, 1tb x4 (minus 2tb for dual redundancy).
Because of the 2 raid layers, it builds the first layer (about 18500 gig), builds the 2nd layer (about 1850 gig) and wants to combine them, but because the volume is over 16tb, it can't expand any further.
I suspect until they roll the 64bit expansion tools into a newer version of raidiator you might well be stuck at 18tb, leaving the 3tb drives not fully used.
if all the drives were of equal size, the volume could be initialized at the max size, and would not be affected by the over 16tb expansion problems... at least until the disks were upgraded again.
Message 11 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-18
08:32 AM
2013-02-18
08:32 AM
It would be nice if there were an advanced option to use 64 bit inode addressing on the initial install.
Message 12 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-18
12:01 PM
2013-02-18
12:01 PM
TeknoJnky wrote: I don't understand anything of that log, but I will make a guess;
That makes sense...perhaps I can convince the Powers That Be to buy an empty 4200...
Message 13 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-18
12:42 PM
2013-02-18
12:42 PM
well make sure its a 4200v2, as the original 4200v1 has the same LSI controller problem as the 3200.
Message 14 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-18
03:20 PM
2013-02-18
03:20 PM
An empty 4200v2 will be hard to find. NTGR sells it as 6 disk and 12 disk populated systems.
Message 15 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-25
01:05 PM
2013-02-25
01:05 PM
How can I tell the difference between the v1 & v2? Other than the pre-populated sizes? CDW has the 4200, but is isn't clear on if its the v2 or not.
Message 16 of 17
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-02-25
01:05 PM
2013-02-25
01:05 PM
The 4200 should have a -200NAS part number, not -100NAS I believe.
Message 17 of 17
