muddauber's avatar
muddauber
Hard Drive Freezes up during backup - ufsdapi_file_flush+365
Netgear ReadyNas 4Plus
I get this message on Netgear Panel
Only when I try backing up one share, the other shares have been
backing up correctly.
ReadyNAS Ultra 4 Plus
Model: ReadyNAS-4200|ReadyNAS 4200
Firmware 6.10.3
    • StephenB's avatar
      Here's what I posted there (just to keep things consolidated):
      StephenB wrote:
      You selected "4200" for the model - which is a rackmount model.  But ReadyNAS 4Plus sounds like you might mean a 4-bay Ultra Plus.  Can you clarify exactly what you have?  Also, let us know what firmware you are running.
      Generally this type of error on the LCD means that the NAS crashed at that location.
      I'd start by testing the USB disk in a windows PC, as UFSD is the Paragon driver that some NAS models use to write to USB drives.
      • muddauber's avatar
        muddauber
        It was difficult to use the Bulletine  Board and find any NAS listed in my original search.
        I have ReadyNAS Ultra 4 Plus with 3 8tb Ironwolf drives, and 1 4 tb HD
        Firmware 6.10.3
        Freezes up during backup with only 1 share folder, the other ones work.
        I ran a virus and malware scan on the drive but still get the error and crash.
ProSupport for Business
