- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help is needed! Do not boot netgear readynas duo v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
A problem from the fact that the hard drive is dead, when installing another disk, the power blinks, three long and three short flashes of 4 LEDs, I press the reset and holding the reset turn on the power, after that the power (flashing) and LED2 light up, pressing the backup button does not give any effect like pressing resets.
I tried to find http://www.readynas.com/hard_disk_hls as recommended in http://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_RU_27Mar12.pdf, there is no such link on the site.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help is needed! Do not boot netgear readynas duo v2
Found https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool, it will help me? I'm loading and waiting ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The tool you found is for Intel based systems and will not work for you.
First, lets be sure you really have a DuoV2. Netgear used the "V2" designation two different ways. What we now call a V2 has a part number ending in -200NAS and says "V2" on the front. If it just says "V2" on a sticker and has a part numnber ending in -100NAS, it's really a V1.
Your NAS is complaining that the root partition is corrupt. Here is the magic decoder ring:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code. Current error codes: 1 - Vendor mismatch 2 - No disks detected 3 - Bad contents on root partition of disks 4 - Flash error 5 - Unsupported RAID configuration
A USB recovery is not the fix for this. An OS re-install is. I suspect you actually have a V1, which is why the V2 process is not working for you. Here is the process for a V1:How-do-I-access-the-boot-menu-on-my-ReadyNAS-Duo-NV-NV-X6-or-600
- Mark as New
- Bookmark
- Subscribe
- Permalink
