Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help with downloading from FTP
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-28
03:55 AM
2011-07-28
03:55 AM
Hi,
I have a question about downloading from FTP via my Readynas Duo. When I google, I only find how to setup the readynas to acces files over FTP.
Just like it is possible to download torrents, I would like to download from a FTP server and store it automatically in a folder on my NAS. Can someone tell me how I should do this? Or is it even possible?
Cheers,
Paul
Cheers,
Paul
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-29
01:11 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-29
01:22 AM
2011-07-29
01:22 AM
Re: Help with downloading from FTP
My guess would be that if you can access files over FTP with your readynas, that's not much different from downloading them.
Aside from that, you can make a backup from a remote ftp server using the options in Frontview. I guess that's the easiest way to do it if you know the files/folders you want to go to since you can browse the folders of the remote FTP server. Using SSH you can probably also directly use the build-in FTP client to browse the folders and download stuff, but i've got no idea how that works..
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-31
11:53 AM
2011-07-31
11:53 AM
I don't think that you know what I mean. I'll elaborate a bit more. With some friends I have a server placed at someone's home with a lot of movies and music on it. I want to download from that server via FTP to my readynas. Not to my laptop and then copy it to the nas.
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-31
11:57 AM
2011-07-31
11:57 AM
I just found this topic:
I see that there is no direct solution, but I'll try the tips that are given there. Any other tips are welcome 🙂
uniquesil wrote: Hi,
I have just purchased my first readynas product and it was because of reading info on these forums so thank you for that.
I currently have a semi-dedicated server with a bittorrent client for downloading my media, I would like to be able to download the files directly from my server to the readynas. Currently I am downloading them through filezilla (on my macbook) and choosing the readynas as the drive but the speed of download is much slower then if I download direct to my mac hard drive.
I don't want to use utorrent on the readynas as the dedicted server is hosted elsewhere and the speeds are much faster than my home broadband.
Is there an add-on that would allow me to download files direct from my server to the readynas? if so, which add-on program would you recommend. I am not very technical so an easy to use interface would be greatly appreciated.
thanks for your help.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-31
12:28 PM
2011-07-31
12:28 PM
Python is a little too complicated for me, I think.. 😞
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
08:16 AM
2011-08-03
08:16 AM
For the recrord: everything works fine with python and pyload. Downloading from my ftp works full speed on my readynas. 🙂
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
10:22 AM
2011-08-03
10:22 AM
If you enable SSH on your ReadyNAS you can use the program ncftp which is already installed. I don't know how comfortable you are with using a terminal but it's fairly straightforward:
-Download and install the add-on enablerootssh from the add-ons page
-SSH to your ReadyNAS writing:
-Type
-Type
-Navigate to where the file you want to download is and type
-The file will download to the folder you were when you first started ncftp
Now, the downside is that the ReadyNAS doesn't support the bgget command which allows a ncftp daemon to download in the background so you'll need to stay connected with the terminal until it's finished. I haven't managed to get the bgget command to work properly but maybe somebody else has?
Have fun!
NB! I'm not sure whether enabling SSH on your ReadyNAS renders your warranty void or not but better presume that it does.
ssh root@readynas-ipin the application terminal on your mac (password is the same as when accessing frontview)
-Type
ncftpand the ftp client will start
-Type
open -u username -p password ip-to-ftp-server
get the-filename-of-the-file
Have fun!
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-07
02:31 AM
2011-08-07
02:31 AM
Thanks for the tips, knorrhane, but I've already got it working with PyLoad. It works fine at the moment!
Message 9 of 9
