× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Help with drive upgrade gone wrong DUO V1
gggplaya
Hi, so i have a Duo v1 and my two 1TB drives are finally almost full after a few years. So i decided to buy a 2TB drive to replace drive 1(volume C). I have it in raid 0 as two independent volumes.
So i used a HD cloning dock and cloned drive 1 onto the new 2TB drive. However, when i put the new drive into the bay, it recognizes it as a new drive ready to go, but has no shares or anything. So i put the old drive back in thinking everything would go back to the way it was, but it didn't.
What can i do to save my data on these drives?? How can i fix the original drive so the readynas recognizes it like it did before? I didn't make any modifications to it, just cloned off of it.
Message 1 of 4
Guru
Re: Help with drive upgrade gone wrong DUO V1
Did you hot-insert the disk drives, or insert them with the unit powered down?
Message 2 of 4
gggplaya
i did a hot swap, which i think is my problem. Didn't know that only works with mirrored drives.
Message 3 of 4
Guru
Hot swap begins by wiping the disk. Hot-inserting your original disk was a big mistake.
You could ask netgear support if a data recovery attempt is worthwhile (support.netgear.com). They would charge for the recovery attempt (whether data is actually recovered or not).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1957 views
  • 0 kudos
  • 2 in conversation
Announcements
