Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to Access to /etc/ ? RN104 6.2.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
03:54 AM
2015-07-06
03:54 AM
Hi everyone...i'm having serveral problems with my nas to make it work with Transimission.
Searching for solving problems i've seen that i can access to /apps/ or /etc/ to check some files but i'm not able to do that.
My nas ip is 192.168.1.100
I've enabled ftp access and ssh on NAS:
I'm on MacOS and when I try to access by Terminal to NAS by SSh I receive the following message:
Mac-mini-de-Juan:~ JuanMa$ ssh admin@192.168.1.100
admin@192.168.1.100's password:
Welcome to ReadyNASOS 6.2.4
Last login: Mon Jul 6 11:33:54 2015 from 192.168.1.38
Connection to 192.168.1.100 closed.
So,nothing happens.
What can I do? It's so frustrated.....thanks!
So,nothing happens.
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
03:56 AM
2015-07-06
03:56 AM
Re: How to Access to /etc/ ? RN104 6.2.4
The SSH user is root not admin.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
04:14 AM
2015-07-06
04:14 AM
mdgm wrote: The SSH user is root not admin.
Good! It worked.
However...still having same problem on NAS.....i'm considering the option to do a Factory reset on nas....
I have 3x2TB hard disk on my NAS....if a remove 2 of them and leave 1 (that could be erased without problems)...if I do a factory reset and after that i put again the other 2 disk...the infomation will be ok on that 2 disk?
I don't want to loose all my data.
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
04:45 AM
2015-07-06
04:45 AM
tjuanma wrote: I have 3x2TB hard disk on my NAS....if a remove 2 of them and leave 1 (that could be erased without problems)...if I do a factory reset and after that i put again the other 2 disk...the infomation will be ok on that 2 disk?
If you will re-insert the other 2 disks, the data that it contains will be all wiped out because it will undergo a resync process.
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
04:47 AM
2015-07-06
04:47 AM
Even if i have all my disk without raid?
I've them in JBOD.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
05:15 AM
2015-07-06
05:15 AM
I've them in JBOD.
For example you have already factory reset your NAS with one disk inside that is already on JBOD and let say XRAID is turned off... the moment you insert the other 2 drives that has data in it one-at-a-time, the NAS will not accept it and you will need to format the other 2 drives. Otherwise, if ever the other 2 drives has no data in it, then you will have the option to add parity.
It would be best to back up of all of your data before anything else. 🙂
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
05:19 AM
2015-07-06
05:19 AM
I've them in JBOD.
What a problem!!
There is any other option to set to default all users/groups/permissions and configurations of the nas without loose data?
Thanks again!
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-06
05:37 AM
2015-07-06
05:37 AM
tjuanma wrote: There is any other option to set to default all users/groups/permissions and configurations of the nas without loose data?
I'm afraid that once you reset the NAS to factory defaults, everything will be all wiped out and you will need to set it up from scratch.
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-07-07
11:22 AM
2015-07-07
11:22 AM
I can CONFIRM that i've made a factory reset witout lost anything...
Doing that:
3x2TB HD (from now i'll refer to they like HD1, HD2 and HD3).
The HD1 haven't any importat information.
HD2 Only Series
HD3 Only Videos.
Removed HD2 and 3.
Started NAS with HD1 and made a Factory Reset. All data in HD1 wiped out.
Reconfigured the "new" NAS only with HD1 inside. (by default the disk is formatted an putted in XRAID-2).
PowerOff NAS and put in HD2 (now inside HD1 and 2). Format HD1 in JBOD and PowerOff NAS again.
Remove HD2 and boot only with HD1 inside.
After cheked that everithing is OK, power off again and install all 3HDs.
Now i've all the 3HDs without lost anything 😉
Doing that:
HD2 Only Series
HD3 Only Videos.
Removed HD2 and 3.
Message 9 of 9
