- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is firmware 6.10.1 safe to install on ReadyNAS 104?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it safe to install this update or will it brick the device again like 6.10.0 HF2 did?
I've already seen posts from NAS users whose devices were bricked by this firmware. I'm a little reluctant to install it to be honest.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is firmware 6.10.1 safe to install on ReadyNAS 104?
Hi @SirToby
Upgrading the RN100 series has an upgrade path to follow if you are on 6.3.x or below
Warnings:
- Devices updated with 6.10.1 firmware should not be downgraded to firmware versions before 6.10.0.
- ReadyNAS 102, 104, and 2120 systems must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then to 6.10.x.
Upgrading the firmware is safe as long as proper procedure is done. Also, doing backups of your data and checking if you have any disk issues before doing so is also a best practice.
Hope this helps!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks mate but that's not quite what I asked. I had upgraded from 6.9.5 to 6.10.0 HF2 and the device had stopped working. It took some manual intervention on the command line to get it back into working order.
I just want to know if all will be fine when upgrading from 6.10.0 HF2 or if it requires manual intervention again in order to get it back up again. I never had an issue but the last upgrade was a bit of an eye opener.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @SirToby, I have a guineapig nas RN104 running fine on 6.10.1 now, while I had issues (not that severe like you) with apps linux-dash and smbplus being on 6.10.0HF2. So, with your good backup at hand you might want to give it a try.
If you like to check some hints to improve performance and stability of RN104 in general you might want to have a look at the collected experiences of mine regarding that model following this link: https://community.netgear.com/t5/ReadyNAS-Idea-Exchange/Improving-performance-and-stability-of-RN104...
Kind regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I'll give it a try
