× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Issue with ReadyNas NV+ after changing a drive
d-k-s
Running in a NAS RND4000 FW 4.1.14 - in a winserver 8 r2 network.
Replaced both drives - one at a time and it seems to have synced well.  But there are a couple of issues:
After changing the password - successfully - it won't let me log in.  I'm using RADAR 6.x
I figure I can take out one of the two drives - and do a factory reset - then resync but is there an easier way?  I'm locked out and the default Admin / netgear1 isn't working either.
Help.
Message 1 of 2
Guru
Re: Issue with ReadyNas NV+ after changing a drive
@d-k-s wrote:
I figure I can take out one of the two drives - and do a factory reset - then resync ... .
That will NOT work.  When you reinsert the original drive it gets wiped.
If you are using XRAID, you could use linux reader to get the files from the data disk (usually in bay 1).  You'd install it on a PC, and connect the disk with SATA or a USB adapter kit.  The link is here: http://www.diskinternals.com/linux-reader/
Is the login failing at https://nasip/admin ?  Did you try both the new and the old passwords?
Also, have you lost SMB access?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2023 views
  • 0 kudos
  • 2 in conversation
Announcements
