Orbi WiFi 7 RBE973
Reply
Issue with my Nas
Yabu
Issue with my Nas
Dear all,
I'm a new user here. I have an issue with my Nas : Netgear ReadyNas RNX7B2000
I don't find my NAS in the drodown menu so I put one, the real model is ; rnx7b2000
When I turn on, I can see directly this :
the leds in front : 1,3 and 4 are blinking alternance with led number 2
Step one : leds 1,3 and 4 turn on and led 2 is off
Step 2 : Leds 1,3 and 4 are off and led 2 is on
I have no possiblity to ping it and not able to go to the web interface management.
I already remove all HDD and turn on the Nas and same issue.
If you can help me, it should be great.
Thanks in advance
Model: ReadyNAS-NV+|ReadyNAS NV+
Message 1 of 5
Guru
Re: Issue with my Nas
I believe you have a ReadyNAS 600B.  That's a very old ReadyNAS - it goes back to ~2007 or so.  Can you post a photo?
The LED patterns are described here: https://www.readynas.com/download/documentation/support/ReadyNAS-LEDA.pdf Unfortunately I don't see your particular pattern listed.
You are seeing the same pattern of lights when the disks are removed?
Do you have a backup of your data?
Message 2 of 5
mdgm-ntgr
NETGEAR Employee Retired
Those are the Rev A patterns.
The Rev B patterns are here: https://www.readynas.com/download/documentation/support/ReadyNAS-LED.pdf
That error pattern indicates that the RAM (memory) is either not seated properly (it may have come loose if you recently moved the NAS) or that the memory (RAM) module has failed.
Message 3 of 5
Yabu
Dear,
Sorry for my late reply, I was on holidays.
Yes it's a very old NAS I will put photo of it.
Yes It's the same case when HDD are removed.
Yes I have a backup of my files, they are visible here :
https://www.noelshack.com/2018-27-1-1530520254-1.jpg
https://www.noelshack.com/2018-27-1-1530520253-3.jpg
Thanks,
Message 4 of 5
Yabu
Ok, I will try to remove the RAM and put other if I have it ... as it is very old.
I will let you know.
Thank you
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 879 views
  • 0 kudos
  • 3 in conversation
Announcements
