- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
JBOD across two disks, one fails
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Community:
I have a ReadyNAS RN102 with two 2TByte disks configured as a single JBOD volume across both disks (Yes, I know). One is now failing with the effect that the NAS's web interface is hardly accessible. I would like to try to copy as much data as possible to a USB drive, but without the web interface being accessible, this is difficult. After a boot, it sometimes loads, sometimes it does not. When it loads and I navigate to another tab, sometimes it works, sometimes it does not.
Does anyone have a suggestion?
I really do not want to hear, that my configuration is risky, I knew that and I still had my reasons. And it is not a catastrophy, if the data on the NAS is lost.
But still, if somone has an idea, let me know.
HAL.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can, turn on SSH as soon as you have any GUI access. Then, you can use the Linux command prompt to copy your files to USB.
It is a shame that Netgear has such a stern warning about SSH, as many suffer the catch 22 of not having SSH enabled when there is a potential fix, or at least work-around via SSH to their issue, had it only already been enabled.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: JBOD across two disks, one fails
I had the same thought. I was not able to switch on SSH via the web interface, but with an app called NAS Utils on my iPhone. Now -- as a Unix novice -- I need to figure out, who to copy the data. At least I can see the disks and partitions via lsbkl now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you first check to see how full the OS partition is?
Start by entering
# mount --bind / /mnt
# df -h /mnt
That mounts sysroot as /mnt, and then shows you the OS partition usage. Normally it will be 25-30% full.
If it is full, then let us know and we can give some guidance on cleaning it.
When done, you unmount with
# umount /mnt
Note the spelling - umount, not unmount.
BTW, make sure you log in as root using the NAS admin password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 748M 3.0G 20% /mnt
- Mark as New
- Bookmark
- Subscribe
- Permalink
And this is how lsblk looks.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 1.8T 0 disk ├─sda1 8:1 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sda2 8:2 0 512M 0 part │ └─md1 9:1 0 511M 0 raid1 [SWAP] └─sda3 8:3 0 1.8T 0 part └─md126 9:126 0 1.8T 0 raid1 /NAS_Bak sdb 8:16 0 1.8T 0 disk ├─sdb1 8:17 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sdb2 8:18 0 512M 0 part │ └─md1 9:1 0 511M 0 raid1 [SWAP] └─sdb3 8:19 0 1.8T 0 part └─md127 9:127 0 1.8T 0 raid0 sdc 8:32 0 4.6T 0 disk └─sdc1 8:33 0 4.6T 0 part /run/nfs4/media/USB_HDD_1 mtdblock0 31:0 0 1.5M 1 disk mtdblock1 31:1 0 512K 1 disk mtdblock2 31:2 0 6M 1 disk mtdblock3 31:3 0 4M 1 disk mtdblock4 31:4 0 116M 1 disk
What's next? rsync?
- Mark as New
- Bookmark
- Subscribe
- Permalink
