Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Kernel Transaction Manager renaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-23
06:14 PM
2012-01-23
06:14 PM
I'm trying to use Fast Picture Viewer to view and edit images stored on my ReadyNAS Ultra from a Windows 7 client.
FPV has a feature to rename viewed files based on a user rating, e.g. {3}IMG0001.JPG where {3} is a rating on a scale from 0-5. When trying this, FPV throws up an error "Cannot rename [file path]. Please verify that the target media or device is writable and that you have proper write permissions. 0x[lots of 0's]". I can rename files just fine in Windows Explorer. I've checked file and folder permissions. Further, FPV can create new files in that same directory on the ReadyNAS and it can also write metadata into the files. It just can't rename.
The FPV author mentioned the following:
FastPictureViewer uses the Kernel Transaction Manager, a feature introduced in Windows Vista and Windows Server 2008, to perform certain file and registry operations atomically.
http://msdn.microsoft.com/en-us/library ... 86748.aspx
Your NAS may not be as 100% Windows-compatible as it appears to be, and perhaps does not support file-system transactions?
He then suggested a registry change to disable KTM. I applied the change, and it worked.
What's up with the ReadyNAS? I'm running 4.2.19.
Thanks,
Adam
Thanks,
Adam
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-29
10:32 AM
2012-01-29
10:32 AM
Re: Kernel Transaction Manager renaming
Anyone with knowledge of the KTM and ReadyNAS?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-29
10:44 AM
2012-01-29
10:44 AM
As the article you quote states:
No ReadyNAS employs NTFS internally
TxF allows transacted file system operations within the NTFS file system.
Message 3 of 3
