× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Leading up to: "Volume scan found errors that it could..."
jpkipps
Where I'm at : Volume scan found errors that it could not easily correct.
What has been happening.
Since June 4, I have been getting volume scan corrected errors six times. Sometimes from me manually rebooting or from the weekly scan.
Other problems I have been experiencing for the past ~6 weeks.
All shares becomes read only; everything is default public, no accounts created. Reboot would fix (via frontview). Happening at least once a week.
Share would become unresponsive, hang. Frontview allowed me to reboot and run a scan / fix. Once a week.
Reformatted USB backup drives, replaced one, unplugged all of them.
Any combination of the above.
~40% of the reboots would result in an unsuccessful boot. Hard off (I usually pulled the power plug and let it sit for a few minutes).
Switched to a new, over sized UPS.
In the past week it has become more often; so I started looking at the SMART status on each drive. One showed 234 reallocated errors. I replaced the drive. Rebuild successful. Rebooted, full check on FS and Quota (no quotas setup). Hung at 77% quota check (hours went by). Hard off, reboot and FS check succesful (repaired).
Everything seemed fine. Dumped the recent vacation videos and photos (5+GB). No problems with the transfer. Then I tried to copy a set of the videos off to edit locally, failed. The box went completely offline. RAIDar finds nothing... Hard reboot. Comes up. Reboot request with FS scan. Never reboots. Ping works, no frontview, no file access. Hard off and power on. Never finished booting. Says Fan FAIL on the front!
Power up and it works great! Backed up my recent file dump (5gb) and reboot with FS check. Quota check to 20% and it completely goes offline (continuous ping starts failing, RAIDar stops finding anything). Front of the unit displays FS 19%, I hard powered off. Will reboot in a few minutes. It's like groundhog day with slight variations. It's super annoying.
Any ideas on how to proceed / guesses?
I cannot consistently create the same problems, so I'm stumped. I keep thinking power supply and after searching; it is probably a good idea. The fans are fine. The connections are solid, no loose screws, etc. There is no dust in the unit (~6 months old?).
fyi: I do have backups, but would prefer not to use them!
Which log file dump is the most useful to put here?
RECENT fs_check.log (before recent failed boot / fs check)
---- START ----
***** File system check forced at Sat Jul 28 15:14:45 EDT 2012 *****
fsck 1.41.14 (22-Dec-2010)
e2fsck 1.42.3 (14-May-2012)
Pass 1: Checking inodes, blocks, and sizes
Inode 21496332 has a bad extended attribute block 343935539. Clear? yes
Inode 21496332, i_blocks is 3552, should be 3544. Fix? yes
Inode 21496333 has a bad extended attribute block 343935540. Clear? yes
Inode 21496333, i_blocks is 2968, should be 2960. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: -(343935539--343935540)
Fix? yes
Free blocks count wrong for group #10496 (29601, counted=29603).
Fix? yes
Free blocks count wrong (693274453, counted=693274455).
Fix? yes
/dev/c/c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/c/c: 169452/75923456 files (2.8% non-contiguous), 521500841/1214775296 blocks
***** File system check forced at Sun Jul 29 13:09:57 EDT 2012 *****
/dev/c/c: recovering journal
Inode 21496793 has a bad extended attribute block 343936006. Clear? yes
Inode 21496793, i_blocks is 16, should be 8. Fix? yes
Inode 21496794 has a bad extended attribute block 343936007. Clear? yes
Inode 21496794, i_blocks is 16, should be 8. Fix? yes
Block bitmap differences: -(343936006--343936007)
Fix? yes
Free blocks count wrong for group #10496 (29603, counted=29605).
Fix? yes
Free blocks count wrong (693274455, counted=688464191).
Fix? yes
Free inodes count wrong (75754004, counted=75752077).
Fix? yes
/dev/c/c: 171379/75923456 files (2.8% non-contiguous), 526311105/1214775296 blocks
***** File system check performed at Sun Jul 29 14:19:06 EDT 2012 *****
/dev/c/c contains a file system with errors, check forced.
/dev/c/c: Inode 21496371 has a bad extended attribute block 343935579.
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
----- END -----
Message 1 of 7
jpkipps
Re: Leading up to: "Volume scan found errors that it could..
Powered on after being stuck at 19% fs check. Did the same thing, stuck at 19%. Another reboot and it came online, but I received the same notice of 'UNEXPECTED INCONSISTENCY'.
It started a resync (x2) and says it has ~5+ hours left. It's online and I copied a gig of files off it with success...
Why the resync?
thanks
Message 2 of 7
jpkipps
Sync completed.
File System Check completed. Updating my USB backup drives.
Crossing my fingers.
Any input is appreciated.
Message 3 of 7
jpkipps
This morning it was offline. No ping, nothing. LCD display said 'resync 1%' . I hard rebooted and it came online; but it's resyncing again.
Anyone?
Message 4 of 7
jpkipps
Sync completed with the same UNEXPECTED CONSISTENCY - RUN FSCHK
I'm attempting to run a full backup again.
Message 5 of 7
jpkipps
It fixed everything and was fine. Now it just started a resync *again!. I officially don't trust it.
I'm done with this.
Building a FreeNAS box to migrate to so I can sleep at night.
Message 6 of 7
ReadyNoob
Hi jpkipps. Have you found a resolution for this? I seem to have exactly the same issue ...
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1457 views
  • 0 kudos
  • 2 in conversation
Announcements
