× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Legacy x86 Pro 6 BIOS files?
mataglap2
Tutor
How would I identify what variant(s) of a black Pro 6 I have?  And having done that, where can I get the newest bios that allows for use of drives larger than 4TB?
I have two, one is an early Pro Pioneer, and the second was bought used, already updated to 6.10.x.
Message 1 of 5
Guru
Re: Legacy x86 Pro 6 BIOS files?
Is there a part number on it?
  • RNDP6000-100 xxx would be the first generation Pro 6
  • RNDP6000-200xxx would be the second generation
I don't recall a bios update being needed for that.  You would need to convert the NAS to OS-6 though.
However, if you want to update the bios before converting it, you can just install this add-on, and then reboot the NAS
Message 2 of 5
mataglap2
Tutor
Thanks @StephenB
Following on from your post, it looks like there are two other ways besides an accurate model number sticker.
By CPU, looking at the /proc/cpuinfo, assuming the unit hasn't been mod'ed.
The -100 would have "model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz" and
the -200 would have (I think) "E5300 2.6Ghz CPU" and
a "Pentium(R) Dual-Core CPU E6700 @ 3.20GHz" is a common-ish mod.
Re the bios, I looked into the upgrade bin you linked to, and the check that script is making
cat /sys/devices/virtual/dmi/id/product_version
and looking for specific strings in the output
"ReadyNAS-NVX-V2", then it's an Ultra 4
"FLAME6-2", then it's an Ultra 6
"FLAME6-MB", then it's what Netgear calls "NV6" and which type of Pro Pioneer/Business/6 variant doesn't seem that important other than to identify the original CPU.  This upgrade takes it to "07/26/2010 FLAME6-MB V2.0"
"ReadyNAS-ProUltra2", then it's an Ultra 2
at least for the units that this BIOS upgrade applies to, which is not the entire ReadyNAS family
my 626X has "ReadyNAS 526 V2.9" as an example of a unit outside the scope of the BIOS .bin file, and my original Pro Pioneer has "10/03/2008 FLAME6-MB V1.6".
Message 3 of 5
Guru
Well, this is the only bios upgrade package for the ultra/pro ReadyNAS products (and you are correct in thinking it does not apply to the entire ReadyNAS family).
Message 4 of 5
Sandshark
Sensei
I remember seeing in the forum that there were some very early Pro6 models that are a bit different and can't have the BIOS updated to accept a faster processor.  But the BIOS update will simply fail on them, not brick it.  But AFAIK, anything with FLAME6-MB V1.6 can be updated to 2.0.  There have been posts on how to do the update if you've already converted to OS6, but they are old.  Personally, I recommend using a spare drive to downgrade back to 4.2.31, then installing the BIOS update, then re-converting to OS6 with that spare drive.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 550 views
  • 0 kudos
  • 3 in conversation
Announcements
