- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lower the volume size/remove a disk permanently?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have started to do a backup of the data, and will do a full factory reset once complete. However there is more data than I have spare space for. So my intent is to remove a disc and use it to do part of the backup.
The question is, while the volume is expandable if I were to put a larger disk in, can the volume be DE-panded? If I remove a disc it will loose the redundancy, but can I tell it to calculate the volume down to the new size?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lower the volume size/remove a disk permanently?
The question is, while the volume is expandable if I were to put a larger disk in, can the volume be DE-panded? If I remove a disc it will lose the redundancy, but can I tell it to calculate the volume down to the new size?
This requires ssh, and is a bit tricky. Not something you should attempt w/o a full backup anyway - so it's probably not the best course. More info on this is here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Reducing-RAID-size-removing-drives-...
Personally I'd suggest investing a large enough USB disk(s) to back up the NAS, and put a regular backup plan in place. Two 8 TB USB drives would cost about $300, and would be enough to back up your current volume. RAID isn't enough to keep your data safe.
@SGT_Oldy wrote:
A hidden snapshot is now read-only for some reason, and the share it is in cannot be deleted.
That was resolved already: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Could-not-delete-share-due-to-snaps...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't think doing that procedure on an iffy file system is a good idea since it has to do a re-sync. Better you just run it in degraded mode with one drive of the RAID missing. Still a risk you lose everything if something goes sideways, but less risk, I think.
