× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
MacOS Sierra, Ubiquiti Unifi AP-AC Lite and ReadyNAS 202 - disk stops being available
smcoll
Hi folks. After booting up I can successfully back up each Mac (all running Mac OS Sierra) to my ReadyNAS 202 using Time Machine. However, subsequent automatic backups fail with "Backup disk not availble". If I restart any one of the Macs then it's able to connect. I suspect that it's a wifi issue - and may be related to the Ubiquiti access points. These are connected to my router (Virgin Media cable modem router) and distributed across the house. Any thoughts on why the connection to the NAS is being lost?
Model: RN202|ReadyNAS 202
Message 1 of 3
JennC
NETGEAR Employee Retired
Re: MacOS Sierra, Ubiquiti Unifi AP-AC Lite and ReadyNAS 202 - disk stops being available
Hello smcoll,
It may be best to isolate the problem first since you are running wireless on the Mac machines. Try connecting one of them via LAN cable to the router/switch where the NAS is connected and disable the machine's wireless connection. Then test again. Please also post the current firmware version of the NAS.
Message 2 of 3
FramerV
Hi smcoll,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1615 views
  • 0 kudos
  • 3 in conversation
Announcements
