× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Memory Upgrade for ReadyNAS NVX?
21alpha
Hi
Superb forum by the way.
Is it possible to upgrade the memory on my ReadyNAS NVX?
I currently have 1GB installed from when I purchased it a number of years ago.
I would like to run Plex on it, for which it does work but a tad slow (LAN is 1GBps btw).
RAIDiator 4.2.30
Intel 4x
Model:ReadyNAS NVX Business Edition [X-RAID2]
Serial:22N296RW0026D
Firmware:RAIDiator 4.2.30
Memory:1024 MB [5-5-5-24 DDR2]
Model: ReadyNASRNDX4220|ReadyNAS NVX
Message 1 of 9
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Memory Upgrade for ReadyNAS NVX?
There are no more Plex updates for the NVX. They have discontinued doing updates for it, so I don't think I would throw money upgrading the RAM in it at this stage.
You'd probably be far better off at this point investing in a new ReadyNAS e.g. RN516 or one of our new products i.e. RN526X (just launched) or RN716X (just launched). CPU matters a lot with Plex if you want to transcode. The RN214 may be worth considering if on a tighter budget. The RN214 can transcode some 1080p to a fixed 480p resolution output.
Message 2 of 9
All Replies
mdgm-ntgr
Message 2 of 9
bedlam1
Prodigy
Have you considered upgrading your NVX from OS4 to OS6 ?
Message 3 of 9
Guru
That can't be done.  The NVX is a 32 bit system, and OS6 need 64 bit.
Message 4 of 9
21alpha
thanks for all the replies guys, highly appreciated.
Theres a quad core 4 bay ReadyNas (NETGEAR RN21400-100NES) on offer at Amazon UK for £280. Would this be sufficient?
I could use my 4 x WD 3TB NAS SATA (3.5") disks in that am sure.
https://www.amazon.co.uk/dp/B015S0Y50C/ref=dra_a_rv_ss_ho_xx_P1200_1000?tag=dradisplay0bb-21&ascsubt...
Message 5 of 9
c3po
NETGEAR Expert
ReadyNAS NVX CPU:
http://ark.intel.com/products/34312/Intel-EP80579-Integrated-Processor-1200-MHz
Please check Intel datasheet for compatible memory modules.
We tested some 2GB SODIMM modules when NVX was in production.
Message 6 of 9
Guru
The RN214 will have good performance.
Message 7 of 9
mdgm-ntgr
Note that the RN214 will need to wipe the disks so backup your data first. Or you could get new disks for the RN214 and use backup jobs to copy the data across then reverse the source and destination of the backup jobs to use the NVX to hold backups of your data extending the useful life of this older device.
Message 8 of 9
21alpha
Thx guys fir all your helpful comments
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4157 views
  • 3 kudos
  • 5 in conversation
Announcements
