Reply
Migrate Hard Drives from one RN104 to another RN104
euphos
I have a new RN104 coming from an RMA for my current RN104. Are there any tricks to swapping the disks from the old one to the new one? According to a couple of threads I read on my search, it appears as long as I keep the order correct, it should work. So I assume I should make sure the new unit is on the same firmware revision (will I need a hard drive in the unit?), then power down both, swap my (4) disks into the new unit, and I'm good to go?
I do have backups if needed, but I hope to not be out of commission too long in the process. My kids TV shows & movies are on the unit!
ReadyNAS 104 6.4.0
ReadyNAS Pro2 6.4.0
Message 1 of 6
vandermerwe
Master
Re: Migrate Hard Drives from one RN104 to another RN104
What firmware is currentLy on the 104?
You are correct, but it would be useful to know what firmware was on when the volume was set up, see here:
viewtopic.php?f=154&t=74192
If you set up the volume before 6.1.5, there may be some value in recreating the volume and restoring from backup or setting up with new disks and copying from old to new nas.
Otherwise, these are the steps ( as you have already discovered)
1. Backup.
2. Spare disk into new nas, upgrade firmware to latest. It needs to be the same or a later version.
3. Power down both units. Remove spare disk.
4. Remove disks from old unit and insert into new unit in same slots.
5. Power on new unit.
Back it up. Use UPS.
Infrant Readynas NV+ | Readynas Ultra 6 Plus | Readynas 316
Message 2 of 6
euphos
I was on 6.2.4, but went back to 6.2.3 Beta 5 trying to fix some problems. I believe I was on an earlier version than 6.1.5 when I originally purchased the unit. Is there a way to determine this by the logs or some other way? Does PHPSysInfo show this somewhere?
ReadyNAS 104 6.4.0
ReadyNAS Pro2 6.4.0
Message 3 of 6
mdgm-ntgr
NETGEAR Employee Retired
initrd.log in the logs shows the firmware update / os re-install history since the last factory reset.
Message 4 of 6
logster_99
Same issue with the lockups here.
I am now trying the beta that some people have had luck with http://www.readynas.com/download/beta/readynasos/6.2.3/ReadyNASOS-6.2.3-T1721-arm.img
Very close to throwing this thing out, getting a Synology and swearing off all Netgear equipment. If Netgear can ship me a replacement with 6.1, you can have the one I have!
Message 5 of 6
logster_99
Update - Netgear replaced my RN104 under warranty and it has been 2 weeks now, one week test, one week with data restored and no crashes so far. Still keeping my fingers crossed.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2249 views
  • 0 kudos
  • 4 in conversation
Announcements
