× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Move Drives From RN2120 to RN3138
Jmeyer00
We have an RN2120 with four 8 TB disks. This unit has been a bit flaky for a few months, and this week has started to fail regularly. I do not think the disks are faulty as the problem followed the chassis even after a complete drive replacement before it was re-deployed to it's current role (secondary backup at our DR site).
We have an RN3138 on site that has smaller disks (four by 4 TB) and is scheduled to be pulled and put into spares. Both are on 6.10.2.
Is it feasible to move the four 8 TB disks from the 2120 to the 3138 without data loss? I did a search, and those replies indicated that it *should* work, but some of the dates I noticed were on the older side (2015-ish). So I wanted to make sure that this is still a viable option.
Thank you.
Model: RN2120|ReadyNAS 2120 1U 4-Bay Diskless
Message 1 of 3
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: Move Drives From RN2120 to RN3138
Hi Jmeyer00,
Yes, it is possible to move the 4x8TB disks from the RN2120 to the RN3138 without data loss since both systems are running on OS6. If you have any apps installed on the RN2120, those apps might not work when you move the disks to the RN3138 because you are migrating from an ARM-based unit to an Intel-based unit. You should at least uninstall the apps first then just install the x86 version of the app after the migration.
It will also be best if you do a full backup before the migration just to be safe.
You may also check this article for reference on OS6 to OS6 disk migration.
Message 2 of 3
All Replies
JohnCM_S
Hi Jmeyer00,
Message 2 of 3
JohnCM_S
Hi Jmeyer00,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 952 views
  • 0 kudos
  • 2 in conversation
Announcements
